Vortech for 97 v6 - Mustang Evolution
Old 07-21-2005, 06:51 PM   #1
Vortech for 97 v6
i wanted to order a vortech supercharger kit for my 97 v6 with 115k miles never rebuild. the kit comes with 8psi and im not sure my car will handle when i buy the vortech and install it do i have to dyno it or is it just fine with installation or do they include somethings thats tunes. oh and any smaller pulley that makes it run smaller boost
TexaStang is offline   Reply With Quote
Old 07-21-2005, 07:21 PM   #2
Danger Dude's Avatar
Smaller pulleys create more boost by speeding up the rotation
Old 07-21-2005, 07:28 PM   #3
Oh My mistake yeah bigger pulley smaller boost i really need to know if i need to upgrade injector and fuel pump and if i need a tune dyno tune
Old 07-21-2005, 07:45 PM   #4
Yes bigger injectors 14's will not do at all. Yes bigger fuel pump and double yes a SCT tune or you will blow the ***** up!!!!
Old 07-21-2005, 07:53 PM   #5
i think the kit comes with bigger fuel pump but sincce my engine is completely stock do i still upgrade in injectors if so what # will 19 be good and will a Sct x-cal 2 do the tuning job
Old 07-21-2005, 07:56 PM   #6
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
I'd get at least 24s
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 07-21-2005, 08:31 PM   #7
well heres and easier question
when i buy the vortech supercharger what other parts should i buy
anyone who has installed a vortech supercharger on a stock v6 pleas help me out what did yall buy
Old 07-21-2005, 10:56 PM   #8
rebuild your engine and build it up before you boost it.
Old 07-21-2005, 11:02 PM   #9
what i wanted to do is supercharge it without having to rebuild
Old 07-21-2005, 11:05 PM   #10
the charger is going to kill such an old engine.
Old 07-21-2005, 11:18 PM   #11
so its no worth it
Old 07-21-2005, 11:30 PM   #12
so its no worth it
nope.
Old 07-22-2005, 05:20 AM   #13
I am going to disagree with 232stang just a bit. The age of the motor and low boost is not going to kill the engine as long as the engine has been well taken care of and you get a dyno tune ASAP. Get a compression check done. you can even get a oil analysis done to check for metal particulates in the oil and filter. I have seen older engines with nitrous and superchargers and still no problems. I will say buiding up a engine is preferable but it can be done on a stock motor with high mileage if the motor is sound. Remember the biggest thing you can do to prevent the supercharger from destroying the engine is to schedule a dyno tune to be done when you get the supercharger in. I have seen to many people blow engines racing around before they got tuned, Get tuned immediately after installation
Old 07-22-2005, 09:15 AM   #14
Where can get a dyno tune done in Texas and how much approximately. so i dont have to upgrade injector right cause its a kit and already comes with a bigger fuel pump
Old 07-22-2005, 11:00 AM   #15
You can buy a complete kit and it will have everything. Where in Texas do you live
Old 07-22-2005, 05:03 PM   #16
South Texas Near Del Rio and San Antonio but might go to Houston. And what do you mean a complete kit do you mean a complete supercharger kit if so will this do
http://www.vortechsuperchargers.com/...ustang_v6.html
http://www.vortechsuperchargers.com/...8-010_list.gif
Old 07-22-2005, 05:09 PM   #17
Some vendors sell complete kits I have not looked at Vortechs site in a while
Old 07-23-2005, 01:18 AM   #18
Kiljosh's Avatar
Correct me if I'm wrong but a complete tuneup and a really good tune will keep your car from blowing up.
I don't know who said it but someone said that it's all in the tune. A safe tune = a living car. An aggressive tune on an old car = a dead car.
Old 07-23-2005, 10:41 AM   #19
Tbird232ci's Avatar
a good tune on any car, regardless of supercharged, turbo'd, nitroused, or naturally aspirtated helps with its long life
an aggressive tune on an older engine wont kill it, because as long as its tuned properly, you should be safe, unless you do soemthing stupid
8psi isnt enough to kill the engine, but 8psi and a horrible tune is, as Danger Dude has been saying, get it properly tuned, pick up a kit that comes with EVERYTHING
the kit youre looking at looks to have everything youd need, it uses a FMU, which with as little boost as youre running, should get you by on stock injectors, but its not the ideal way to do it
Old 07-23-2005, 12:35 PM   #20
I agree with Tbird232ci the FMU is not the way to go. It fakes the system by adding additional pressure to the stock injectors. 14's are just to small. There are barely enough for even a mildly built engine. A upgrade to 19's or 21 is a would be much better but actually I would go to 30's or a little higher if I was to go with a supercharger
Old 07-23-2005, 12:50 PM   #21
Tbird232ci's Avatar
once again, i agree with Danger Dude, if you get some bigger injectors, say 30# injectors, and you get your car tuned for them, you can eventually upgrade and have room to grow, and just need to have it tuned, rather than going, buying some 19# injectors, then later buying 30#, and then later going to 42# etc
as Danger Dude said, an FMU basically inscreases fuel pressure at the FMU see's boost, a typical pressure regulator will increase fuel pressure 1psi per 1psi of boost, so for example, if you run 38psi base fuel pressure, and you have 10psi of boost, you will have 42psi of fuel pressure under boost
with an FMU, you can have them increase fuel pressure anywhere from 1 to i think 6psi depending on the FMU per pound of boost, so say youre running 38psi base pressure again, with 10psi of boost, and 2psi per pound of boost, youd be seeing 58psi
at a certain point, your injectors wont be able to flow any more fuel, your pump wont be able to supply more pressure, and youd have to upgrade anyways
Old 07-23-2005, 12:59 PM   #22
BINGO!!! :thumbs2: :thumbs2:
Old 07-23-2005, 05:57 PM   #23
Kiljosh's Avatar
Prices though, do they even change depending on how big an injector you get?
For example like 220 or so for a new set of 19's, basically same price for a new set of 30's or no?
If yea then I say why not just save yourself the 200 bucks down the road?
Old 07-23-2005, 07:00 PM   #24
19's can be found cheap. All 5.0 and 4.6's till 98 had 19's. You can pick up good used 19's for 50-70 bucks all day long. Even used 30's are a little high because they are in demand for high N/A HP and supercharged engines
Old 07-23-2005, 11:42 PM   #25
Tbird232ci's Avatar
depends if you know where to look
i can find 19# injectors all day in the junkyards, then you find somewhere that reconditions them, cleans them and flow tests em, itll be probably about 50-70 bucks total, for like new injectors
if you know what to look for, and where to look, you can find some good stuff
Corey...who woulda thought we'd be agree'n with eachother, you big dick
3.8 Vortech Supercharger 67mustang97 Pre-2005 V6 Mustang 11 11-10-2009 11:53 AM
Vortech S trim Js281GT 1996-2004 Mustang GT 22 08-06-2006 12:27 AM
How much HorsePower!!! Vortech!! black95SVT 1979-1995 Mustang GT 5 11-22-2005 07:09 AM
vortech oaktonarcher Pre-2005 V6 Mustang 0 08-15-2004 05:12 PM
Installing a Vortech SC Danger Dude Pre-2005 V6 Mustang 19 11-03-2003 10:48 AM
10:23 PM
