weak braking - Mustang Evolution
Old 07-24-2005, 11:29 PM   #1
weak braking
Lately my brakes don't seem to stop like normal. I seem to have excessive pedal travel especially during low speed stops. If I slam on the brakes at low speeds (before the abs treshhold) my wheels don't lock up. I have fairly new pads on the front and rear (<8,000 miles) and I tried bleeding the brakes and didn't get any air. Any ideas?
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 07-25-2005, 12:21 AM   #2
is everything lubed up?
Old 07-25-2005, 12:06 PM   #3
Send a message via AIM to tedness
yes always make sure to have plenty of lube.
hmmm how recent are they? that does seem a bit wierd tho for them to do that.
tedness is offline   Reply With Quote
Old 07-25-2005, 03:59 PM   #4
make sure you dont have a brake fluid leak, if its bad you will smell the fluid when you get stoped after it gets on those hot rotors.
Keep an eye on your fluid level and check the caliper banjo bolt (dont OVER tighten it of course) and where the line goes into the hard line with a LINE WRENCH. Same goes for back.
Old 07-25-2005, 09:54 PM   #5
I checked the fluid. No problem there. After closer inspection my pad doesn't seem to be wearing uniformly. I'm busy at school but i'm going to investigate further on wednesday. Thanks for you help
-Denver
Old 08-07-2005, 04:46 PM   #6
Re: weak braking
Alright so I checked everything and the rotors were shot. I changed the pads and rotors and everything seemed better for a few days. Now I have the symptoms again. My pedal feel sucks. Do you think it could be the master cylinder? I've double and triple checked for leaks and there isn't any. I'm running out of ideas. Any help would be much appriciated.
-Denver
Old 08-07-2005, 05:27 PM   #7
Re: weak braking
Did you bleed the whole system really well?
Old 08-08-2005, 08:42 AM   #8
Re: weak braking
yep everythings been bled
-Denver
Old 08-08-2005, 10:24 AM   #9
Re: weak braking
is the brake booster still good? do a check for me. turn on the car and push the brake in once, take your foot off the brake and turn off the car 5 seconds after. once the car is off try pumping the pedal, it should still be soft just like when the car was on for the first 2-3 pumps.
Old 08-08-2005, 07:04 PM   #10
Re: weak braking
Thanks for the suggestion but I had already checked that too. (forgot tho mention it). The booster is fine.
-Denver
Braking wiarumas General Car Discussion 10 07-02-2008 01:48 PM
questions about braking charkelly9 Pre-2005 V6 Mustang 2 03-28-2005 02:12 PM
braking tech oaktonarcher Pre-2005 V6 Mustang 11 02-25-2005 03:46 PM
Braking issues fastmustangs1 Pre-2005 V6 Mustang 3 10-10-2004 10:54 PM
03:05 PM
