Ok made up my mind... going to swap for a manual and need input - Mustang Evolution
Old 07-27-2005, 04:07 PM   #1
I need a complete part list that I am going to need.
It will be a T-5 and more than likely be bought used.
Other than the tranny what will I need? I have a bellhousing for a T-5 already... I assume it fits any kind right?
Other than the tranny and bellhousing what am I looking at?
It would be nice if links to where I can purchase it would be provided.
Items listed so far
Shifter
T-5
Pedal Assembly
Clutch Pressure Plate
Clutch Disk
Throw Out Bearing
Pilot Bearing
Reburn Chip for it
Clutch Cable and Assembly
Wiring Harness
Flywheel
Bellhousing
Throw Out Bearing Retainer
Where to get these items:
Quadrant, Clutch Cable and Firewall Adjuster
Old 07-27-2005, 04:44 PM   #2
i belive it will work with any t-5 (your bellshousing) glad you are comming over to the fun side of the fence You need quite a bit, mainly wiring harness, tranny, clutch pressure plate, clutch disk, throw out bearing, pilot bearing, flywheel, manual tranny computer/chip to change settings, couple other this and thats.... there was a full kit available maybe you could get an itemized statement to what they include. If you buy used get a pre 99, and get a GOOD one.
Old 07-27-2005, 07:24 PM   #3
Danger Dude's Avatar
No one has said pedal assemblies. You will look kind of foolish with a manual tranny and no clutch pedal !!!!! DOOOOOOOOOOOH!!!
Old 07-27-2005, 07:44 PM   #4
Send a message via AIM to tedness
i guess the gas pedal is re-usable, so a clutch and brake. or just upgrade to a whole new set of like bullitts or something.
guessing you have gears and such already? maybe get a new set and an installation kit so everything in your rear is fresh. and if you have the money go ahead and get a stage 2 clutch and happy flywheel to save time down the line of labor. do it all while its out to save a hassle.
tedness is offline   Reply With Quote
Old 07-31-2005, 11:26 PM   #5
So help me out guys....
Got to get a complete list:
Got:
Bellhousing
Need:
T-5
Pedal Assembly
Clutch Disk
Throw Out Bearing
Pilot Bearing
Reburn Chip for it
Wiring Harness
Shifter
What about the flywheel? I receieved a new one with my new engine parts.. Alumnium... can I not use it?
What else do I need other than that above? I need a COMPLETE list of everything.
Old 07-31-2005, 11:57 PM   #6
go for aluminum flywheel, but make sure the teeth are steel.
that's the best way to ensure it'll last. you can re-surface the aluminum, but if the teeth are aluminum they can break off easily.
Old 08-01-2005, 12:01 AM   #7
I got an aluminum flywheel with my new engine setup
Old 08-01-2005, 07:42 AM   #8
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
i think you need to add wiring harness to the list
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 08-01-2005, 08:11 AM   #9
You will need a clutch cable and assembly
Old 08-01-2005, 11:46 AM   #10
Added those things... now what am I missing if anything? If that is all I need to start gathering a price list and find where to buy this stuff
Old 08-01-2005, 12:00 PM   #11
shifter.
Old 08-01-2005, 12:02 PM   #12
Originally Posted by 232stang
shifter.
Thanks, going with a Steeda Tri-Ax
Old 08-01-2005, 12:15 PM   #13
So where can I find the following?
Pedal Assembly
Clutch Disk
Throw Out Bearing
Pilot Bearing
Reburn Chip for it
Wiring Harness
Old 08-01-2005, 12:21 PM   #14
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
what kinda clutch are you gonna get?
19ClearCobra96 is offline   Reply With Quote
Old 08-01-2005, 12:23 PM   #15
Spec Stage 2
Old 08-01-2005, 01:07 PM   #16
i have a spec stage 2 brand new i might sell.
as for the other parts try calling midwest mustangs. or go here http://3.8mustang.com/forum/forumdisplay.php?f=63
Old 08-01-2005, 01:41 PM   #17
Re: Ok made up my mind... going to swap for a manual and need input
check out the mgw shifter also, ive heard great things about it and the steeda is noisy... if i had it to do over I would definatly consider the mgw.. they have AMAZING quality parts.
Old 08-01-2005, 01:44 PM   #18
What all comes with the clutch you have? TO Bearing.. Pilot Bearing?
And how much?
Old 08-01-2005, 01:56 PM   #19
And how much?
It should have everything. When I bought my stage 3, it came with everything needed for installation. The only extra part I had to get was the firewall adjuster and quandrant because the plastic ford one sucks donkey balls. By the way, I would recommend the UPR triple hook quadrant and firewall adjuster. Since you are swapping you might as well get the kit which also includes an adjustable clutch cable. I think it is like $50-$60 for all 3 in the kit.
Btw, how much HP do you hope to have when all is said and done? The reason I ask it, if you hope to have mega power like my V6 build is hoped to have, a stage 3 might be a good idea. But, a 2 should get you by until you decide to push moded 03/04 cobra type numbers.
Old 08-01-2005, 02:05 PM   #20
Yea I dont plan on having those numbers for a long time.. by which I will have to replace the clutch anyway I bet....
I am guessing I will sit at 240ish to the wheels for awhile...
I will get the UPR one you suggested and stage 2 spec clutch
Old 08-01-2005, 02:06 PM   #21
I assume that when I am selecting parts I select for a 79-95 since I am using a T-5????
Old 08-01-2005, 05:17 PM   #22
And how much?
every thing exceptt the pilot bearing but it has the clutch, pressure plate, TO bearing, and clutch aligner tool. i dont know how much to sell it for though i payed abut 300 and i have not even installed it so i would prolly like to get 300 out of it.
Old 08-01-2005, 05:22 PM   #23
DO NOT use the throwout bearing that comes with a spec clutch it is a major POS... use an oem ford... not that they are much better. I have a pilot bearing and a fork arm brent if you need it. You may not can use the fork arm...ill have to try to find em.
Old 08-01-2005, 06:09 PM   #24
lol dude... they changed the spec bearing from plastic... last I heard and it was a huge improvement over stock
Old 08-01-2005, 06:14 PM   #25
I'll give you 250 shipped for it since no pilot bearing.... but I cant tell you when i can get you that money I still have to get this damn engine rebuilt and then hope my tranny can be fixed enough to where I can drive it.. cause I am not paying over 100 bucks to fix it.. if its more than that she is getting parked.
Old 08-01-2005, 06:17 PM   #26
I started typing this type of response to it, but I changed my mind since I have stated it about 3-4 times before. It obviously isn't believed. My TOB is just fine. The Ford ones have TSB on them.
Old 08-01-2005, 06:49 PM   #27
yea, fords suck... I have been though 4 and on my way to go though my 5th throwout bearing.. and I DO NOT abuse mine... if it wasnt for my perfect adjustment keeping on my clutch the current bearing would be trashed by now.... it ticks if I let it get unadjusted.... ford TB's blow... the old spec ones were just worse. I went though one TB in a week.
Old 08-01-2005, 07:40 PM   #28
brand new they are like 360, plus shipping, i know a pilot bearing is worth a hell of alot less than 100 bucks. and mine is brand new, its just sitting in its box. for 250 shipped i would rather put it in my car.
Old 08-01-2005, 09:17 PM   #29
Sorry I thought they were 300 new
I will do 300 shipped then
Old 08-01-2005, 09:35 PM   #30
Hey, I just remembered a link I saw when I was looking at crate engines for my V6 build. Super six has a write up of everything you need to do the swap. Here it be http://www.supersixmotorsports.com/PDF/T5SwapFAQ.pdf . It has some things that you don't have listed.
Old 08-01-2005, 09:41 PM   #31
Why did you not just by a 5 speed stang when you had the chance????
Old 08-01-2005, 11:05 PM   #32
look around and see how much they are and give me links i dont wanna give it to you for 300 then find out that they had a some major price cuts.
Old 08-01-2005, 11:28 PM   #33
when your ready to buy hit me up by then i might make up my mind on whether to sell or not.
Old 08-02-2005, 01:41 PM   #34
I told him OVER AND OVER AND OVER AND OVER AND OVER AND OVER AND OVER to get a manual but he would NOT get oen saying he does not want one and he ONLY wants an auto.... next time maybe he will listen....
Old 08-03-2005, 05:22 AM   #35
Rick0636's Avatar
If you put a good shift kit in a Mustang Automatic they do a great job in my opinion. I had a B&M in my 99 and I think I liked it as well or better at times than a manual.
'04 GT Swap-out automatic trans for 6-speed manual ctogni1 1996-2004 Mustang GT 1 01-14-2010 01:29 AM
transmission swap (auto to manual) what parts? 6opka Pre-2005 V6 Mustang 8 04-02-2009 03:26 AM
made my mind up....for once o3mustangGTafs 1996-2004 Mustang GT 18 08-05-2006 10:21 PM
Made up my mind!! Danger Dude Pre-2005 V6 Mustang 39 03-10-2005 06:03 AM
what do i need to swap from auto to manual 97GtStang 1996-2004 Mustang GT 15 08-13-2004 08:09 AM
06:41 AM
