shifting problema - Mustang Evolution
Old 07-27-2005, 10:30 PM   #1
shifting problema
my 95 was having major difficulties shifting into first gear when stoped and didnt shift into any gears easily i was told to get a new clutch i did and it helped some what but still harder than it should be any ideas?
95stang_man is offline   Reply With Quote
Old 07-28-2005, 10:39 PM   #2
Send a message via AIM to tedness
hmm check the shifter to see if it's greased up well. that could do it. an aftermarket shifter might just compound the problem.
tedness is offline   Reply With Quote
Old 07-28-2005, 11:16 PM   #3
I liek gramer
WhiteStang99's Avatar
problem in Spanish is a male word: "problemo"
Not problema! That's female! There's your whole problem right there.
Old 07-28-2005, 11:37 PM   #4
check the clutch petal and if it has to much slack, as if the petal is on the floor and what not then that may very well be the problem. You can get a clutch petal height adjuster from maximum motorsports.com, cluch quadrent, and firewall adjuster. These will let you adjust your clutch along with keep it from being WAY up in the air as aftermarket quadrents/firewall adjusters do.
Shifting problems blue-saleen Pre-2005 V6 Mustang 4 09-08-2009 07:55 PM
Cluthchless Shifting 2000StangLover Mustang Audio & Video 15 10-28-2008 03:44 PM
Flat Shifting doinurx 1996-2004 Mustang GT 41 05-13-2007 08:58 AM
Shifting feel KyleUSAF Pre-2005 V6 Mustang 6 02-15-2005 10:28 AM
Shifting on Automatic megax29 Pre-2005 V6 Mustang 52 07-15-2004 11:14 AM
09:12 PM
