Engine Swap for a 3.8 v6 Mustang - Mustang Evolution
Old 10-04-2009, 07:31 PM   #1
Send a message via AIM to Firewolf
that's what I'm looking for. But I need info.
I've heard that there were a number of Thunderbird models that had built in S/C. That's what I'd like to jump for, but I don't know what models and what years to look into. I have a guy willing to pass me a 3.8 t-bird engine with 92k miles on it [which has about 100k less than my current 3.8]
But. I've also another guy with a 1985 3.8 v6 LX motor....
I'm looking for basically the cheapest most efficient / power increasing swap...and info about those thunderbird years and models to look for the S/C so I save money on a 3k+ supercharger for this car.....
Firewolf is offline   Reply With Quote
Old 10-04-2009, 10:02 PM   #2
Re: Engine Swap for a 3.8 v6 Mustang
Suggestions for other motors of similar build [preferably with the S/C built in] are more than welcome also. those are just the ideas I've stumbled across. I've also found another fellow who has a 95 Tbird 3.8 engine for sale....would that drop in ?
Old 10-13-2009, 05:46 AM   #3
Send a message via AIM to dtbback
well man if you are going to do an m90 swap you may want to reconsider. Look on craigslist for a 99+ 3.8l (split port) motor can usually be found for pretty cheap and then get the m112 adapter from supersix motorsports. You will get a imporved motor and a larger super charger with better cooling and then if you want to run stock internals don't rund mor that 8psi of boost. Cheapest swap. Your tranny should mate up because I am pretty sure you have a t5 so all you need to do is pull the motor and swap in the engine and ECU. I am sure there are more specific instructions but that should take care of it.
Will
dtbback is offline   Reply With Quote
Old 10-13-2009, 07:19 AM   #4
yea the supercharger does not transplant from the thunderbird to the mustang, basically you need the entire engine.
You can take your single port (4 intake runners vs 8 intake runners on 99-04 3.8L) and build it and end up wtih 220rwhp-250rwhp. This will take stroking the engine, porting the heads, intakes, cam, crank, pistons, tune, etc
Old 10-13-2009, 01:54 PM   #5
Zebs5408's Avatar
waste of time doing a m90 swap! THE GAINS ARENT WORTH THE TIME OR MONEY! i got everything almost then realized how much i could lose by switching to single port heads! youll need the single port heads, lower intake, upper intake, water pump, all kinds of brackets from an s/c, the m90 with all the piping and intercooler with the intercooler boot, bigger injectors, umm and whole bunch more crap! DONT DO it lol
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
v6 mustang
98 Mustang Engine Swap 06TC88 1996-2004 Mustang GT 1 04-26-2009 05:55 PM
Engine Swap on a V6 2003 Mustang. Ride the Pony Pre-2005 V6 Mustang 7 04-25-2009 11:31 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap - Chevy 4.3 into Mustang? IcedIllusions Pre-2005 V6 Mustang 5 10-05-2004 07:42 PM
04:23 AM
