Tuner... Worth it or not? (2000 v6) - Mustang Evolution
Old 10-08-2009, 12:26 PM   #1
CHILE10_STANG's Avatar
Question Tuner... Worth it or not? (2000 v6)
I HAVE A 2000 V6 WITH A CATTED X PIPE (HI-FLOW) AND A COLD AIR INTAKE. I USE SYNTHETIC EVERY 2000 MILES AND I USE 93 GAS... WOULD A TUNER BE WORTH IT? DOES IT REALLY DO THAT MUCH TO A CAR?
HELP!
THANKS!
IMPOSSIBLE IS NOTHING
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
CHILE10_STANG is offline   Reply With Quote
Old 10-08-2009, 01:33 PM   #2
OsirisGuy's Avatar
Re: Tuner... Worth it or not? (2000 v6)
Yes.
I'd give details, but I have class soon. Hopefully someone else here will chime in why.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-08-2009, 01:50 PM   #3
upton7's Avatar
The tuner kinda but the tune is what makes the power the tuner simply loads it into the car and can do little things like read codes don't get a mail order (online) tune you to a tuning shop and have them put it on a dyno and they can actually flash it straight to your can and you don't have to buy a tuner but you can't read codes but that is free at auto zone and you cant save your stock tune
Old 10-08-2009, 06:16 PM   #4
Does anyone know any dynos in va? I live in alexandria...
2000 MUSTANG V6
2001 MUSTANG GT
2014 MUSTANG GT
Old 10-09-2009, 03:35 AM   #5
Send a message via AIM to dtbback
CHILE, as far as a tuner goes it will give you some performance gains but whether or not they will be cost effective after buying the tuner and having it programmed will be subjective. It is really better suited for a car that has internal modifications so that you can get your mods to be at there most power efficient.
I would say you have a good start but before you go spending your hard earned money on any more mods figure out where you want your car to end up, what you want to use it for, and how much you want to spend. Always better to know where you are and where you want to go before you begin your journey.
Will
dtbback is offline   Reply With Quote
Old 10-09-2009, 06:45 AM   #6
Herbstang's Avatar
Get the tuner it's well worth the money even on a motor with basic bolt-on a UDP will also wake the motor up.If you have the cash get some gears 3:73 for manual 4:10 for auto and if your not tuned for 93 your just wasting your money a 93 octane tune kick *** compared to the 87 factory tune
Incomplete combustion can happen running 93 octane with the stock tune causing carbon build up and premature catalytic converter failure
Higher octane burns at a differant rate
Old 10-09-2009, 08:37 AM   #7
autos do a lot better than manuals due to the ability to tune the trans. Dont change your oil every 2k miles unless you only drive 2k miles a year. Do it every 3k.
Old 10-13-2009, 12:10 PM   #8
Zebs5408's Avatar
tuner + gears is the best investment budget wise you can make!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 10-16-2009, 07:53 AM   #9
edross's Avatar
highly reccomended for automatics, hell it even downshifts, if you are going to use 93 octane you should have it tuned for 93
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 10-20-2009, 05:51 PM   #10
red97's Avatar
i would def get the tuner i got a switch chip from sct with a 93 tune and it really wakes the car up but with the switch chip you have take/send it back to who you bought it from to retune if you get more mods for your car if you plan on getting more stuff done to your car i would get a tuner you can retune yourself
red97 is offline   Reply With Quote
Old 10-22-2009, 09:55 AM   #11
The Darkside's Avatar
Tuner is the way to go. just make sure its not a canned tune. have somone GOOD tune your car. the diffrence can be night and day.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 10-28-2009, 10:07 PM   #12
DEG
hey herbstang whats the 3/8 Phenolic Intake Spacer for
DEG is offline   Reply With Quote
Old 10-29-2009, 07:04 AM   #13
Herbstang's Avatar
It add length to the runners more HP/TQ and lower the temperature of the intake manifold cooler temps more power Before the spacer I dynoed at 188/215 to the wheels afterwards 193/221 not a huge increase But worth the 80.00 bucks
Old 10-29-2009, 02:34 PM   #14
DEG
what year do you have u have a 6 right. i got an 04 3.9L where would i be able to get that if i wanted to. im not going to buy it till after the gears tlok and tune but just to know where i can get it
2000 dollars worth of damage... ouch. Black_Sunshine Pre-2005 V6 Mustang 14 09-07-2010 07:00 AM
2000 gt gears and tuner combo? pmushock 1996-2004 Mustang GT 12 04-15-2009 02:19 PM
think its worth it???? bobbyoooo 1996-2004 Mustang GT 11 12-22-2008 09:22 AM
How much are YOU worth? bluemustang The Bar 60 01-30-2005 11:03 PM
worth it thirstymate The Bar 3 09-02-2004 08:20 PM
02:14 PM
