New CAI - Mustang Evolution
Old 08-04-2005, 08:46 AM   #1
Send a message via AIM to Murph00
New CAI Help!
I have a larger MAF that a buddy gave me, its inlet is 3 1/2 inches I was wondering if I made a CAI with tubes from lowes or wherever would my cpu on the car add a little fuel to get the right mix or do I need to program the cpu? Is it worth doing the bigger MAF or should I keep the stock.
Murph00 is offline   Reply With Quote
Old 08-04-2005, 10:57 AM   #2
slvr2000stang's Avatar
Re: New CAI
If you change the MAF the transfer function in the EEC would also have to be changed either through a chip or flasher.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-06-2005, 10:43 PM   #3
Rick0636's Avatar
Re: New CAI
That sort of depends, a C&L maf does not require that, because it uses the stock MAS, or electronics, just a larger maf body.
Old 08-07-2005, 07:04 AM   #4
Re: New CAI
That is true.
I had one a long time ago, for a short time.
2000 Vert 4R70W
Old 08-07-2005, 08:24 AM   #5
Re: New CAI
Ha, I've have seen it go many ways. Sometimes they work they way they are intended, they lean the car out a little bit and make more power (from leaning the car out, not because they flow more air). I have seen them make cars run pig rich, and make cars run so lean that they can barely support combustion.
I say stay away from them unless you are pegging the stock maf or it becomes a restriction. HCI 4.2 probably needs an 80mm maf. Supercharged car running suck-through needs an 80 or 90mm maf.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
cai
afe stage 2 cai or C&L racing cai b's stang 2005-2010 Mustang GT 5 05-20-2010 06:25 PM
CAI Taywi Pre-2005 V6 Mustang 17 06-30-2007 08:45 AM
need a cai mustang0386 Mustang Parts for Sale and Wanted 4 12-03-2006 08:33 PM
Cai. Seph Pre-2005 V6 Mustang 15 06-21-2005 05:32 PM
98 V6 Cai Ibanezplayer272 Mustang Parts for Sale and Wanted 3 12-05-2004 05:32 AM
11:45 PM
