I'm embarassed to ask, but WTH - Mustang Evolution
Old 08-05-2005, 07:23 PM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Question I'm embarassed to ask, but WTH
i know this sounds stupid but what's the difference between a 3.8 V6 and a 4.2 stroker??
I know that when you stroke it's the same as boring and creating a larger displacement (longer stroke length). when it says that it's a stroker engine does that just mean it's a V6 that's been bored out? is it easy as that or is there a more in depth explanation?
positive feedback welcomed.
I_luv_HP&trq is offline   Reply With Quote
Old 08-05-2005, 07:56 PM   #2
Re: I'm embarassed to ask, but WTH
Please post in the V6 area next time
Old 08-05-2005, 08:09 PM   #3
Thomas91169's Avatar
whats the difference?
more displacement means more power.
-Thomas-
Old 08-05-2005, 09:34 PM   #4
Monkey's Avatar
stroke and bore are not the same. Stroke has to do with length of piston travel. Bore is diameter of the cylinder. Increasing the diameter of the cylinder (boring) of a 3.8 will only really get to a 3.9, if that. Stroking requires a new crankshaft that increases the throw of the piston.
Old 08-07-2005, 08:50 AM   #5
Rick0636's Avatar
Good explanations guys! boring will get some additional power, but not that much, there is a limit to how much you can bore an engine, or you could go into the water jacket or just make the cylinder walls too thin. Stroking is done by changing the crankshaft, also sometimes with the piston rods a little bit.
wth....shop wants 1k for installs tedness Pre-2005 V6 Mustang 13 07-14-2005 10:52 PM
08:03 PM
