Pinion Gear Shims - Mustang Evolution
Old 10-09-2009, 01:42 PM   #1
Pinion Gear Shims
I am new to the forum and wanted to first say Hello to all and to Thank those who took the time to reply to my introduction post. -- Thanks
Down to business:
2000 V6 7.5 rear end w/ production 3.27 gears. Looking to upgrade to the T-Lock limited slip and a gear swap to 3.73 or 4.10, not sure yet. I considered the 8.8 from a salvage yard, however I dont want someone else's past trouble and I already know my 7.5 is in great shape and not look to run over 300 HP.
With that said, the pinion gear install has me a little concerned, been hearing horror stories from others, but I still want to attempt it myself. When the pinion gear is installed, it is my understanding that the shim washer goes between the hub and the bearing, then install and torque down and check run pattern. So, if you have one known, the original ring and pinion and shim used in that set up, I still have two unknowns, the new ring and pinion gear. So what to do? Also, if I miss on the set up then I have to remove the entire pinion and disassemble without screwing up the bearing and try it again? Will removing the press on bearing ruin the new bearings?
I have done a lot of research, but I am still a little confused about part of the install.
Thanks for your help
V6Terry is offline   Reply With Quote
Old 10-10-2009, 12:07 PM   #2
Wink Re: Pinion Gear Shims
I found a great tech article on the American Muscle web site that answered most of my questions. I had read it before, but after studying the project and reading it again, I found exactly what I was looking for.
Thanks again
Pinion SC_STEEDA Pre-2005 V6 Mustang 6 07-29-2008 04:42 PM
8" 4.11 Richmond Gear Ring and Pinion New in the box kellyjc Mustang Parts for Sale and Wanted 0 07-01-2006 10:27 PM
Rack and pinion Ponycarman Pre-2005 V6 Mustang 13 06-17-2005 06:27 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
11:44 AM
