squeaking sound from engine - Mustang Evolution
Old 10-09-2009, 02:59 PM   #1
hi guys i have a 99 with a 3.8 and there seems to be a squeaking sound coming from a little round thing located behind the water pump could somebody please tell me what this thing is called and what does it do?........thanks
midnightrider_s is offline   Reply With Quote
Old 10-10-2009, 09:02 AM   #2
67mustang97's Avatar
Region: Vermont
Re: squeaking sound from engine
Behind the water pump? Do you mean the idler pulley? They sometimes squeak or make a whirling sound. They are cheap and easy to change. If it's not a pulley I'm not sure what the little round thing is lol...
Old 10-10-2009, 10:57 AM   #3
MonteCitan's Avatar
With the car running, spray the belt with a little bit of WD 40 (watch your eyes, and be safe of course)
If it's the belt possibly cauisng the squeal, the WD will make it stop for a bit.. in which case.. Replace your belt
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-10-2009, 03:38 PM   #4
its the camshaft position sensor making a terrible squeaking noise it started doing this friday and since its started making this noise it has started to miss also but what im wondering now how hard is it to change this thing
Old 10-10-2009, 04:42 PM   #5
Region: Vermont
Do you still have oil pressure? It may be a bigger problem then the sensor.
Old 10-12-2009, 07:39 AM   #6
^^ the oil pressure sender in 96+ is 100% worthless it just goes to the middle of the gauge and sits there regardless... basically it comes on at 6psi ... which is stupid since if you only have 6psi its already a dead engine.
the cam position sensor, never replaced it but it cant be to hard
HELP-Thudding sound - engine: Manfold? chris7869 Pre-2005 V6 Mustang 7 08-22-2007 06:44 PM
To get rid of squeaking... crazeflier07 Pre-2005 V6 Mustang 0 08-08-2007 08:14 PM
2000 mustang GT tapping sound in engine dreamcar00 1996-2004 Mustang GT 8 01-19-2007 04:58 PM
Engine knocking sound (video inside) Brent Pre-2005 V6 Mustang 19 12-02-2004 11:32 PM
Squeaking Noise joekool9 Pre-2005 V6 Mustang 3 08-03-2004 09:38 AM
03:40 PM
