wierd clank - Mustang Evolution
Old 10-09-2009, 09:30 PM   #1
v6stang04's Avatar
wierd clank
i went to the drag races tonight, i did 4 runs. the last wasnt so pretty. i did a burnout to warm up the tires. pulled up to the line took the overdrive off and brake torqued it. well when it finally got traction, a weird pop happened. the car still drives, but occasionally it has a pop coming from the rear of the car. i have no clue what it is. it does it alot more when i turn left or right. my question is, is it the suspension, the gears, the entire rear end, the axle, driveshaft. please help me with finding out what it is. for the stuff i have done to the car is: dual exhaust, bbk 65mm throttle body, bbk shorty headers, bbk cai, and a programmer. but it has not been reprogrammed with the new throttle body on.
v6stang04 is offline   Reply With Quote
Old 10-09-2009, 11:03 PM   #2
OsirisGuy's Avatar
Re: wierd clank
I would have to say it something with the rear end, not sure exactly what part though.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-10-2009, 11:28 AM   #3
MonteCitan's Avatar
Re: wierd clank
Lift the car off the ground (not using the rear axle, so the suspension drops down)
Look at all your bushings/check all your bolts and mounts - Something may have shifted/slipped/broken or come loose during the launch or burnout
And check your rear brakes/ebrake as well, doing a burnout will heat up the rear brakes realllly fast
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
wierd noise ??? yoshiStang19 Pre-2005 V6 Mustang 20 08-05-2009 03:36 PM
Wierd Sound Justin 1979-1995 Mustang GT 15 12-11-2006 11:35 AM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
A wierd little kit. Dom Mustang Audio & Video 14 06-30-2004 03:25 PM
Wierd Noise badazzstang Pre-2005 V6 Mustang 3 12-11-2003 01:27 PM
01:45 PM
