Got my 1/4mile times... - Mustang Evolution
Old 10-10-2009, 09:50 PM   #1
mystanghurts04's Avatar
hey, went to the track for the first time last night, i ran a 16@86mph. i dont have a scanner, but i will write them down. also, weather was terrable, i think when it gets cooler, ill be in the mid 15s easy.
R/T .189
60' 2.230
330 6.529
1/8 10.100
miles per hour 68.01
1000 13.310
1/4 16.000
miles per hour 86.01
mystanghurts04 is offline   Reply With Quote
Old 10-12-2009, 07:42 AM   #2
Re: Got my 1/4mile times...
your 60ft needs work, you can widdle it down to a 2.1 which in the end would shave off .2 at least on your times. Overall if your car is an auto thats not a bad time at all, wont get much better if your stock. If you are a manual you have 15.5s in it no doubt.
Remember 01-04 v6s redline at 5500 rpms not 5250 as the cluster says (thats 99-00 models)
Old 10-12-2009, 07:57 AM   #3
well, it was my first time, and the track wasnt preped very good, also it was way to hot out that night, olmost 95' out. anyway iam going back sometime next week. i actualy ran a 15.9 at 87mph, but redlighted, so i guess it didnt count, then the car was to hot i guess. but like i said iam going again next week so hopfully it wil turn out better.
Old 10-12-2009, 01:13 PM   #4
redlights are meaningless if you are just running aginst the clock so it counts. The clock doesnt start till your car starts to move, doesnt matter if you sit there for 5 seconds or redlight it will still be accurate.
Old 10-13-2009, 01:57 PM   #5
Zebs5408's Avatar
what all have mods do you have?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 11-29-2009, 02:27 PM   #6
rinfield2004's Avatar
what mods do you have? and theres a few "tricks" you could do to shave a little off. Lower back tire pressure, increase your front tire press., gut your car (back seats, trunk, etc.), turn your T/C off, O/D off, launch in Drive, set your revs to 1500rpm (assuming your trans is stock), light drops, release the brake and hang on.
rinfield2004 is offline   Reply With Quote
Old 12-01-2009, 10:27 PM   #7
DEG
how much do you lower the tire pressures?
DEG is offline   Reply With Quote
Old 12-02-2009, 09:39 PM   #8
roughly 40-45lbs for the front and roughly 15-17lbs (assuming you have drag radials) for the back, work your way down 1lb each pass until you find that happy median.
Old 12-02-2009, 10:30 PM   #9
BIG_K's Avatar
60 ft's look normal for street tires.. i ususally cut 2.0 60 ft's with mine on dr's and 1.9 with the stickey mickey's.. keep it up man sixers are fun!
BIG_K is offline   Reply With Quote
Old 12-03-2009, 07:17 PM   #10
I'd have to concure with Big_K. Indeed they are.
Old 12-06-2009, 12:20 AM   #11
ohhh, wow, this is an old topic, i wasnt gona post up again till i went back to the track. when i went however, i had an intake manifold spacer, cai, and flowmaster 40s, with a mac H pipe. the track was just **** that day, and my tire presser was just under spec for the back, and normal for the fornt. but, i have added a few things since then, so 15s, will be easy as hell. now i have the sct 93 tune, p&p tb, and the windstar intake is going on soon, so i will have new times soon. also, ac and radio was off, speaker box was out, spair was in tho, quater tank gas. thats as gutted as it will get. and as far, as the stall speed, its still 1900, so i dont have to much room to work with... and i did it in drive to.
Old 12-07-2009, 12:08 AM   #12
BIG_K's Avatar
4.10's and spray will get ya in the 14's.. lol
Old 12-07-2009, 07:20 AM   #13
just keep going, practice is the number one best mod to have
Old 12-07-2009, 08:12 PM   #14
BIG_K's Avatar
^TRUTH^
New Best Times stangin99 Pre-2005 V6 Mustang 49 04-20-2005 10:01 PM
E.T. Times Js281GT 1996-2004 Mustang GT 14 03-02-2005 02:00 AM
New Times auto6banger Pre-2005 V6 Mustang 30 01-19-2005 11:51 AM
My Times timpryor Pre-2005 V6 Mustang 3 12-20-2004 12:38 AM
best times Fishers Stang Pre-2005 V6 Mustang 4 08-02-2004 03:21 PM
04:51 AM
