I need help - Mustang Evolution
Old 08-17-2003, 07:23 PM   #1
I need help
Ok, this problem wasnt adequetly answered in the other forum, and also i have another related question for EVERYONE.
So anyways today im driving, and for the past couple weeks my damn steering has been making this screeching noise whenver i turn, and the front end creaks when i go over bumps. I dont know what the F*** happened, because it just started all at once. The guy at goodyear gave me some bull**** about a bushing "giving me play" in the front, and im like "WTF am i supposed to do with that". Oh yeah, my back brakes need to be replaced to. What a piece of ####. AHHHHHHHHHHHH
so anyways i was wondering...
1. Has the steering squeeking happened to anyone else?
2. WHAT IS MY PROBLEM!?[/u]
http://www.mustangmods.com/data/1581/sig3.jpg
Check out my car on cardomain!
CAI (99+), 17" 01' GT rims, Hankook hrII tires, interior switch pony, dressed up engine (blue), other numerous appearance mods
Sil\/erSpeed is offline   Reply With Quote
Old 08-17-2003, 07:34 PM   #2
With the steering its more than likely due to low Power Steering fluid levels. Check out that first. And if it is low fill it back up and check for leaks.
It could possibly be one of your bushings. Take it to several places and dont tell them what you think it is but what is wrong and let them look at it and see what all the different places say.
Old 08-17-2003, 07:46 PM   #3
fast64's Avatar
I had screeching and creaking in my steering and my ball joints were bad.
GO BRAVES
Old 08-17-2003, 07:53 PM   #4
Black95GT's Avatar
Send a message via AIM to Black95GT
I havent had that problem....yet
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 08-17-2003, 10:50 PM   #5
Me either........
MoRpHeUs
I have come for the octane, the whole octane and nothing BUT the octane.
Any questions?
Morpheus is offline   Reply With Quote
Old 05-11-2005, 10:48 AM   #6
happing to me right now as well, horrible screeching, and creaking, ive lubed everything under there, I think It may be bushings, but not sure how hard are those to replace?
munny is offline   Reply With Quote
Old 05-11-2005, 10:49 AM   #7
Its like if I push down on the passenger side front tire it creaks somthin horrible, like an old rusty door hinge.
any ideas?
Old 05-11-2005, 11:06 AM   #8
Danger Dude's Avatar
any ideas?
If you have recently lowered the car the new contact pionts on rod ends change and squeek. Take some WD-40 with the red plastic straw provided and shoot it in the area where the ball and socket meet. I would recommend doing this with the front end on jacks an the wheels off the ground so you can move the wheels while doing this.
Old 05-11-2005, 12:41 PM   #9
I liek gramer
WhiteStang99's Avatar
try flushing your power steering fluid if none of what has been suggested works.
Old 05-11-2005, 02:20 PM   #10
Bane-'s Avatar
my truck did that, can u push down on ur fenders above ur wheels and it makes the noise? if so its most likely ur ball joints. and for your sake hopefully ford put a grease fitting on there and u can just regrease them, my truck has no grease fittings. had my uncle (who works for goodyear actually lol) get a guy to cut a small slit in the boot to grease it up, replacing my ball joints is gonna cost $500-$700
Old 05-11-2005, 03:42 PM   #11
ya if I push down on the fender and actually push the whole body downwards, I get the creak, car is all original no new suspension work or anything. diddn't do it all today, a rainy day biut yesterday was somthing terrible
Old 05-11-2005, 04:42 PM   #12
check and fill power steering fluid then try to lube all bushings.
Old 05-11-2005, 09:16 PM   #13
tire's Avatar
Send a message via AIM to tire
if it is a simple squeeking it may be a worn bushing, or a lowering spring installed without a spring isolator...
a screeching like that sounds more like a ball jt. IMO. take it to another shop.
tire is offline   Reply With Quote
Old 03-06-2006, 09:05 AM   #14
Send a message via AIM to BigL34461
Re: I need help
ok i'm a newbie so don't be mad at me....How can i flush my power steering fluid myself??
BigL34461 is offline   Reply With Quote
Old 03-06-2006, 02:31 PM   #15
I liek gramer
Re: I need help
I've asked the same question myself.
power steering issues
Don't be afraid to make new threads. This is an old thread and most people probably will not check it.
01:01 AM
