rear swaybar advanatges? - Mustang Evolution
Old 08-09-2005, 12:57 PM   #1
Send a message via AIM to tedness
ok i know its an easy-as hell install to do, so i wanted to know what it'd help w/ on our cars?
i do auto-x and wanted to know how it would help. was planning on getting one shipped to me b4 this sunday's event
edit: i have a lot of understeer.
tedness is offline   Reply With Quote
Old 08-09-2005, 01:16 PM   #2
Re: rear swaybar advanatges?
Yes it will help a ton in Auto-x
Old 08-09-2005, 01:35 PM   #3
werd
Old 08-09-2005, 02:10 PM   #4
Danger Dude's Avatar
It was insane for Ford to stop putting them on the V6's to begin with the damn cheap *** bastards!!! There is only gain in putting one on. There are no negatives. The second you take a corner with one on you will understand. The back in does not lift as much or want to come around in tight corners
Old 08-09-2005, 03:02 PM   #5
haha thnx. that was the first helpful info in the replies
ya i stopped by our guy today at ford/lincoln/mercury and he hooked me up w/ a stock GT swaybar and the nuts/washer mount thingies for rite at $100. will be in tomorrow.
the GT bar is supposed to be better than cobra because of the shape between the transition at the corners from round to square. less likely to break at that point apparently.
Old 08-09-2005, 03:46 PM   #6
I have a Cobra rear sway bar but I also have a Cobra front sway bar. I dont see it breaking HAHHAHAHAHHA. But a GT sway bar is more than enough!!!
Old 08-09-2005, 03:58 PM   #7
The Cobra Sway Bar Which Is Prone To Breaking Is The 98 I Believe
Old 08-09-2005, 06:03 PM   #8
Actually it is the 96-97 and it broke right at the bolt hole. I have a friend with a 96 at work that it happened to. But it is not that common and there was a problem with a certain lot of the swaybars
Old 08-09-2005, 07:49 PM   #9
ah ok. i didn't think the 99+ would be like that.
but ya i'm gonna put it on tomorrow and see how it does. what should i look for in terms of changes? the back end wont feel so high on corners? what else?
Old 08-09-2005, 08:01 PM   #10
I need to put mine on...and yes, my car has a bad tendency of wanting to drift around when I'm pushing it, hoping maybe the rear swaybar will fix that.
Old 08-10-2005, 05:33 AM   #11
It will !!!!
Old 08-10-2005, 05:35 AM   #12
But you cant use a 99+ Cobra sway bar on a GT or V6 unless you put an IRS rearend in the car
Old 08-10-2005, 08:47 AM   #13
figured as much. bwahahha i'd fab something. bwahahhaa
Old 08-17-2005, 10:58 PM   #14
97Stallion's Avatar
I put my sway bar in and DAMN, my rear it SOOOOO tight now. before it felt so loose. In fact is was so loose I could squel my tires. But now I have the new control arms, the 8.8 w/3.73s and the rear sway bar. That thing ain't moving at all!!!
Living one day at a time!
Old 08-18-2005, 09:34 AM   #15
I told you!!!!!
Old 08-18-2005, 09:48 AM   #16
Tbird232ci's Avatar
it really helps balance out the car, corners flatter, and does help reduce understeer
Old 08-21-2005, 09:37 PM   #17
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
It does help with the understeer, and it does corner flatter, and more predictable. If I could find the time to put these springs on, I'd probably notice a difference with those too, huh?
232stang01 is offline   Reply With Quote
Old 08-23-2005, 05:26 PM   #18
I had less oversteer with mine... not a massive difference though. They are cheap so get one... (used junk yard 99+ gt one)
Old 08-26-2005, 07:10 PM   #19
Ponycarman's Avatar
I'm thinking of pulling mine off. I have too much oversteer. It get's squirelly in curves.
Of course I don't have a stock rear suspension, or front. Maybe I'll just up the front bar instead.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 10-19-2005, 08:46 PM   #20
Region: Iowa
The Thread From The Dead Bwuahahahahahahaha
I just got some better sway bars for my car from an 86 T-Bird Turbocoupe
1 5/16" front
5/8" rear
It stiffened up my car a bunch, and I had to relearn how to drive it. It was a good thing. Still haven't reached its limits yet, but I push the envelope a little more each day.
I hardly notice body roll anymore, and my tires dont squeal as much going through turns and curves.
1990 Mustang LX 2.3Turbo
Turbo Swap, 5-Speed Swap,Adjustable Boost valve(set at 15psi), Walbro 255lph(high pressure) fuel pump, 35# Injectors, Garrett T-3 Turbocharger(.60/.63)
4sd4d is offline   Reply With Quote
Old 10-20-2005, 06:39 AM   #21
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
I put my bar in and DAMN, my rear is SOOOOO tight now. before it felt so loose. That thing ain't moving at all!!!
:pnoid:
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-21-2005, 10:59 PM   #22
hahah super placebo
swaybar carlosc Pre-2005 V6 Mustang 11 12-25-2008 09:08 PM
Finally installed rear swaybar!!!!!!!!!!11one WhiteStang99 Pre-2005 V6 Mustang 24 11-14-2005 01:32 PM
Finally installed rear swaybar!!!!!!!!!!11one lowflyn Pre-2005 V6 Mustang 19 11-13-2005 07:42 PM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
99+ GT Rear Swaybar Shahrum Mustang Parts for Sale and Wanted 3 03-17-2004 02:55 PM
11:10 AM
