exhaust/power question i need the 2 cents! - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 10-11-2009, 09:31 PM   #1
Senorjizzy is unknown around these parts
Send a message via Yahoo to Senorjizzy
Arrow exhaust/power question i need the 2 cents!
my cats have been rattling horribly (worse everyday), and have just ben thnking bout getting them cut off. but im going to replace them. should i buy stock? or go aftermarket?
2nd, while im getting this work done, ive planned on going with an H-pipe and some sort of flowmaster exhaust setup. ive been told that with 2.5 piping ill lose back pressure. so what mods would make up for this loss in power?
id really appreciate everyones 2 cents. i need this bad.
maroon 1998 mustang V6 auto. AM cai. Raxiom black headlights )
Senorjizzy is offline
Old 10-11-2009, 11:07 PM   #2
sonicpony03 is unknown around these parts
Re: exhaust/power question i need the 2 cents!
If you're gonna go with new cats, I'd look into hi flow aftermarket cats. Pypes, Magnaflow, SLP, they all offer hi flow cats for our mustangs. This way you're only stuck with 2 cats and will still be emissions legal.
The 2.5" piping is standard on pretty much all aftermarket systems. You really won't lose that much backpressure...or torque, maybe 1-2 ft.lbs. A set of under drive pulleys would recoup that slight loss in torque. They are cheaper than the 99-04 udp's, so I would consider them for your car.
03 Sonic Blue Pony
Mods in Garage
Quit Lurking! Join Mustang Evolution Now!
http://www.mustangevolution.com/foru...eferrerid=7896
sonicpony03 is offline
Old 10-12-2009, 07:15 AM   #3
Terminator Owner
SpectorV is just getting started.
after owning 2 v6s I would NEVER cut the cats off, they sound bad enough with just a catback up high. Down low they sound fine but up top, not so much. I would pick up a take off Y pipe with all the cats in good shape and put it on.
SpectorV is offline
Old 10-12-2009, 01:00 PM   #4
wow i never thought of that. but how owuld i tell they are in good condition? anything i should look for specifically?
Old 10-12-2009, 05:34 PM   #5
SaturnMan8227's Avatar
SaturnMan8227 is unknown around these parts
Send a message via AIM to SaturnMan8227
Well first off remving the cats is illegal. Depending on your state you could geta fine and not pass an emissions test. With that said I would get some magnaflow high-flow cats. They are obdII compliant and should be street legal. You probably won't notice any loss in hp or tq if you go with a 2.5in pipe and mufflers. Depending on what sytem you buy(custom or pre fab) you might actully gain hp and tq.
SaturnMan8227 is offline
Old 10-12-2009, 07:27 PM   #6
lowflyn is unknown around these parts
Just stick with 2 1/4 piping. It'll flow any amount of power you are wanting to put down and it's cheaper than 2.5.
And on a V6, keep the cats. I had an offroad x pipe on my old v6 and it was just bad..
lowflyn is offline
Old 10-12-2009, 11:51 PM   #7
I'm pretty sure he is going to replace the cats somehow, that's what he said in his op. He wanted to know if he should go with stock or aftermarket cats.
I agree with lowflyn on the piping. The easiest way is to retain the 2.25" piping all the way through. A takeoff GT catback will retain the 2.25 piping, though they can be harder to come by these days, I'd check a local salvage yard for a GT or cobra. I don't know if exhaust shops fabricate 2.25" piping, I'd imagine so, but I haven't been to one in a few years
03 Sonic Blue Pony
Mods in Garage
Old 10-13-2009, 10:16 AM   #8
A muffler shop should be able to fab a 2.25in pipes. shouldn't be a problem since the shooukld have that size for imports
Old 10-13-2009, 10:24 AM   #9
^^^That's true
03 Sonic Blue Pony
Mods in Garage
Closed Thread
exhaust
Please give me your 2 cents on this Pro Charger for Shaundra DDTCM 2005-2009 Mustang GT 35 04-01-2010 11:41 AM
Power Question 00StangV6 Pre-2005 V6 Mustang 5 01-19-2006 05:15 PM
Power question coolstang Pre-2005 V6 Mustang 10 12-30-2004 09:53 PM
Power adder question ShwoffGT 1996-2004 Mustang GT 4 11-01-2004 03:45 PM
airbag power question WhiteStang99 Pre-2005 V6 Mustang 10 06-12-2004 12:35 AM
07:49 AM
