KN heatshield problem - Mustang Evolution
Old 08-11-2005, 10:53 PM   #1
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
alright so ive had the K&N FIPK for a while now..today i was out on I80 and i noticed my hood on the passanger side ( around the area of my filter ) was bouncing and lifting up a little bit with the air. it finnally unlatched ( didnt pop up but it came undone as it would if i pulled the release peice inside the car ). pulled on the sholder pushed the hood closed and went back home. I came to the conclusion that my heatshield where it goes along the side of my filter is hitting the underside of my hood causing this to happen, any idea s of how i could stop this ? would it be possible to make a chalk line on the heatshield and trim it down enough so it wont hit ?
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 08-11-2005, 11:42 PM   #2
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: KN heatshield problem
i just got rid of my heat shield all together since my filter sits in the fender well. I was told that heat shields have an advantage and disadvantages. disadvantage is that all the cooler air is being forced into your intake but the engine itself doesn't recieve that cool air since it's blocked by the shield.
i don't know if that creates a problem or how accurate that statement is. don't quote me cuz i just heard it.
anyways yes you can trim it down with a dremel or something like it. it must be hitting the underside of your hood pretty damn hard to have it get loose like that. are you sure it just didn't get shut all the way? i know you gotta slam the hood down good. maybe use a zip tie or bolt it down somehow. just random suggestions....
I_luv_HP&trq is offline   Reply With Quote
Old 08-11-2005, 11:48 PM   #3
Dark02Pony's Avatar
yeah what i noticed after closing the hood numerous times just to test it is its nice and secure all over except for a little flex around my filter area where i can lift my hood just a little.im prob just going to dremel the heatshield a little bit.the kn fipk needs the heatshield because its what the MAF bolts up to and also holds the filter and the lower part of the intake tube secure by bolting up to my ac compressor
Old 08-12-2005, 12:24 AM   #4
Hm...I haven't noticed this problem with mine...
Old 08-12-2005, 10:07 AM   #5
If you compare the fact that the heat shield blocks the fenderwall hole just like the stock box with cone does, you will realize that statement is false. The hole in the fenderwall is not for engine cooling at all. It is solely for the intake of cool air from outside the engine compartment. Not sure who told you that info, but they are just silly.
Old 08-12-2005, 04:00 PM   #6
so its poping the hood..... or making it rattle or what exactly
Old 08-12-2005, 04:46 PM   #7
Dark02Pony's Avatar
i called up KN they're sending me a new 1 but as i get to 65,70mph that part of the hood will acually lift up and down from all the air getting under where its not secure and it eventually de-latched. didnt pop up but how it would if i pull the hood release
Old 08-12-2005, 04:51 PM   #8
hmm. maybe the new one will fix it, very odd though.. try with oem air box and see if the same thing happends (the control set for the experiment)
Old 08-12-2005, 04:54 PM   #9
Dark02Pony's Avatar
yeah im hoping the new 1 will fix it , we shall see ..but thats a good idea im going to put the stock airbox onto the intake tube then take it out on the highway and see if it does that same i didnt think of that thanks looks like its about to downpour any second but once it clears up im gonna get right on that
Old 08-13-2005, 10:57 AM   #10
01mineralgrey6's Avatar
when i had one on my v6 i could see on the underside of the hood where the sheild was hitting the insulator(sp?) but never had that kinda problem... maybe you can bend the bracket a little bit where it bolts to the a/c compressor?
-Tony
'99 cobra 'vert
Old 08-13-2005, 12:04 PM   #11
Dark02Pony's Avatar
installed the stock intake system so i could see if the hood still flopped around and it does with the KN fipk and without so i guess it has something to do with the latch or something
Old 08-13-2005, 12:09 PM   #12
yea, probably something with the latch, i would get it checked/fixed asap
Old 08-13-2005, 03:38 PM   #13
Dark02Pony's Avatar
yeah im gonna get it checked out monday or tuesday at the dealer
One last problem, help. blue-saleen Pre-2005 V6 Mustang 10 08-16-2010 03:51 PM
97 A/C problem phaw16 1996-2004 Mustang GT 7 07-20-2009 12:39 PM
Problem.. lowflyn Pre-2005 V6 Mustang 15 07-25-2005 12:52 PM
06:32 AM
