V6 without fog harness - Mustang Evolution
Old 08-13-2005, 12:26 PM   #1
i got my cobra front bumper on fog and all but there is not harness for me to hook em up. im afriad to splice into the headlights power but would that work. anyone who has done this please let me know what to do. thank you
Tony
2002 Silver V6 Mustang
my garage http://www.mustangevolution.com/gara...do=view&id=273
TBone is offline   Reply With Quote
Old 08-13-2005, 01:54 PM   #2
Kiljosh's Avatar
Re: V6 without fog harness
Goto radioshack and buy a toggle switch. Hook that up to a ground, the power to your fogs and a hot wire(like your cig lighter) and your done. Might want to look into getting an inline fuse just incase.
Old 08-13-2005, 02:29 PM   #3
There is a how to I wrote around here some where.... its a pretty simple install if you have a little wiring experience. The reason I choose the driver side head light is due to the fogs will turn off when the headlights are off, and you cant leave em on... unless you leave the head lights on as well. The headlight comes out very easy.
The best thing to do is pop the driver side head light out and use a power tester to find the parking light (amber bulbs) hot wire when the parking or headlights are on. Once you find the wire that is hot when the parking lights or the head lights is on then you need to mark it since it will be the one you splice into.
Its best to use a relay, but you dont have to. Use the wire you found on the drive side head light to power the fog lights, you wont have the correct connectors to mesh with the fog lights, so go to ford and pick up some, take the fogs with you to make sure they work... cuz the ones ford had didnt work on my 03 cobra fogs.
You can make your own fog light connectors if you wish... just tape up the area good and you should be fine.
Thats about it, power the fogs from the drive side head light's amber side bulb via the wire that is hot when the parking lights or the head lights are on. Use a relay if you want to, works better, and of course have an in-line fuse with in 18 inches of the battery.
Its best to stick in a switch or use a fuse thats easy to disconnect in case you need to turn the fogs off, and keep them from comming on.
Buy red and black wire so you can keep track of hot/ground wires. Ground the fogs on the negative battery terminal or on a good chassis location.
If you need any more help feel free to buzz me here or via pm/AIM
Old 08-13-2005, 02:51 PM   #4
97Stallion's Avatar
Where did you get your cobra front bumper? I'm looking for one.
Living one day at a time!
Old 08-13-2005, 03:34 PM   #5
he has an 99 up, the cobra bumper for those are far cheaper and easier to find.
Old 08-13-2005, 08:37 PM   #6
Send a message via AIM to NJStang86
I believe VMPtuning.com sells foglight harnesses for these types of instances if you didn't want to make your own harness.
-Frank-
http://home.earthlink.net/~riz3742/sig2.jpg
2003 Ford Mustang Dark Shadow Gray Coupe - 15.616 @ 87.24 (work in progress)
NJStang86 is offline   Reply With Quote
Old 08-15-2005, 01:11 AM   #7
I got in a minor accident. did about 4000 worth in damage. was going to ge the cobra front bumper anyway but this way was cheaper. mine as well just of done it now. hopefully getting my car back now. happened on the 24th of july. been without it since. had to get a rental. it sucks
Tony
Old 08-15-2005, 05:53 AM   #8
slvr2000stang's Avatar
That's where I got mine. Includes factory switch, relay, wiring, connectors & instructions.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
94 5.0 ECU harness help popawoody 1979-1995 Mustang GT 11 03-22-2009 01:02 AM
o2 harness Crazyhorse347 1979-1995 Mustang GT 4 10-27-2008 05:43 PM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
5 point harness! fastmustangs1 Mustang Audio & Video 2 05-18-2005 06:05 PM
Be careful with that harness!! ASSEMbler Pre-2005 V6 Mustang 10 11-04-2003 05:36 PM
04:03 AM
