starting off - Mustang Evolution
Old 08-14-2005, 04:14 PM   #1
Question starting off
okay so i'm thinking about adding some mods to my 95 3.8 and i have a few questions....
1) are the cold air intakes on ebay worth the money or should i go with k&n or something?
2) which would be better mod to start with cai or udp?
3) if i get an exaust will i lose hp or torque? i remember reading somewhere about a guy losing power off the line because of the loss of back pressure...
thanks for the help
-j
utmusicnut is offline   Reply With Quote
Old 08-14-2005, 10:13 PM   #2
Kiljosh's Avatar
Re: starting off
I would do Underdrive pullies first as I actually felt something when I did them, not like when I put a Cold Air on.
Old 08-15-2005, 03:01 PM   #3
Re: starting off
CAI is a cheap and easy mod, i would do it first to get your feet wet. It doesnt add much hp/tq, probably wont notice any difference...but it is a step along the way.
I would then do a UDP, exhaust, and rear end gears/tlok.
Old 08-15-2005, 03:02 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: starting off
It all depends on what you want to do with your car....I would get an exhuast system first. it will be more noticeable and help your car sound and breathe better. If anything i gained HP from mine. If you get true duals you'll have more exhaust flowing through and i would think since it's flowing through two mufflers you would have more back pressure and not less. someone correct me if i'm wrong.
as far as CAI goes i would hold off on it and just get a nice K&N filter. I felt no difference with my Mac CAI. You may feel a difference if you do more mods to your car and all the performance mods will work together...but by itself i don't think it would do much but look pretty under the hood. why would you want to add something that makes no difference? i think it's a waste of money to get that first.
I_luv_HP&trq is offline   Reply With Quote
Old 08-15-2005, 03:10 PM   #5
Re: starting off
The bottom line is, no matter how much you do bolt ons dont do much of anything. Rear end gears will give you the BEST bang for the buck PERIOD for the price. With gears in your car you will shave off over half a second depending on ratio from your current times. Thats a good bit.... with all the bolt ons you should not expect more than .3 tenths off....
Old 08-15-2005, 04:10 PM   #6
Re: starting off
yea but it depends on what he wants to do. for some people they don't care about shaving off half or a tenth of a second or whatever, they just want a little more power then stock. not everyone drag races. that's why he needs to figure out what he wants. i agree that gears would make a much better improvement, but expensive if you can't do the labor yourself. that's why i suggest doing the exhaust system.
there's never an easy solution to any of this unless you have all the tools and knowledge.
Old 08-15-2005, 04:51 PM   #7
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: starting off
my K&N intake gave me noticably better throttle response for sure, i donno about power but..it also sounds awesome when you accelerate and you have teh whistlage
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 08-15-2005, 05:43 PM   #8
Re: starting off
I was just using how much faster the car would go to give an idea of the gains.
Old 08-15-2005, 07:38 PM   #9
Danger Dude's Avatar
Re: starting off
Yes most are worth it
UDP provides more of a gain on a stock motor but we are only talking about a couple of extra HP
This is the biggest load of poop that spreads thru the internet. If you have your cats on you really are not going to lose anything. Dual exhaust on a stock motor is like 2 hp and the loss of torque is laughable. Now if you remved the cats and put 2.5 in pipes you might lose some.
thanks for the help
-j
Your welcome
Old 08-15-2005, 09:12 PM   #10
slvr2000stang's Avatar
Re: starting off
Gears are a great upgrade. Even on the street they give a nice kick.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-21-2005, 07:43 AM   #11
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Re: starting off
the UDP is a fairly easy thing to swap out, and I did notice some improvement. Duals are a good idea, find some takeoffs from a GT or a Mach1. The CAI didn't do that much, if anything at all, but it makes it sound cooler. I haven't done gears yet, but it's a good thing to have done, I'm just cheap.
I'd start at the UDP. other than gears, it would be the most noticable.
However, in terms of which bolt on/mod is better, more often than not, the last one you do will be the best(or it'll feel like that, anyways).
Good luck!
232stang01 is offline   Reply With Quote
Old 08-21-2005, 09:52 PM   #12
Ponycarman's Avatar
Re: starting off
Austin, huh?
I work there.
I put duals on my 96, I noticed no change in the way of power, sounds nicer though.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 08-28-2005, 12:28 AM   #13
Send a message via AIM to tedness
Re: starting off
well you'll want gears...as you have 2.73's and 99+ had 3.27's
maybe a brake upgrade because you have only 1-piston calipers
udp for sure, helps more on your car than 99+
get cold air and put on a k&n filter in place of the one that comes on it
tedness is offline   Reply With Quote
'02 V6 starting point JonL1 Pre-2005 V6 Mustang 9 10-15-2009 05:32 AM
Just starting need help V8HUNTER Pre-2005 V6 Mustang 20 08-08-2008 02:01 PM
trouble starting bluestang1724 Pre-2005 V6 Mustang 2 05-23-2006 04:08 PM
Starting Problems Zak Attack 1979-1995 Mustang GT 16 05-17-2006 07:54 PM
10:19 AM
