power loss? - Mustang Evolution
Old 08-18-2003, 12:53 PM   #1
power loss?
Umm, I dunno if this is an obvious problem, but I've noticed a very noticeable loss of power out of my stang lately. It's to the point that I have to rev the engine higher to get the same power out of it that I used to. Did I lose a cylinder or something, (because that's what it seems like it)? This really sucks because I was just about to start putting some $$ into it.
6erstang is offline   Reply With Quote
Old 08-18-2003, 01:18 PM   #2
Monkey's Avatar
is the check engine light on?? if so that may be telling you the problem.
you should go get a compression check done. if that comes back okay, check the transmission. it may not be transferring power correctly. are you getting any weird sounds with it??
Old 08-18-2003, 02:29 PM   #3
nah, no check engine lights or anything and no weird sounds either. I have recently done several maintenance items like radiator flush, oil change, plugs, wires, throttle cleaning, and a new filter--
Old 08-18-2003, 02:55 PM   #4
Danger Dude's Avatar
Might have a bad plug or plug wire. I had to go thru 3 set of plugs before I founfd 6 that met my standards. Just one plug with a small little imperfection at the end of the threads on the plug on the dyno after changing it was worth 6 hp
Old 08-18-2003, 05:06 PM   #5
I actually replaced new plugs in the beginning of the summer so I know it's not those (unless one went bad). My dad has the tools to test the cylinders so I think that's what I'll do if this problem doesn't scream something else to you guys--
Old 08-18-2003, 07:55 PM   #6
Blow the car up???? HAHHAHAHAHHAH Just kidding
Old 09-03-2003, 01:29 AM   #7
PuReHeLL's Avatar
Send a message via AIM to PuReHeLL
Another problem what had happened to my friend with power loss and he had thought it was his exhuast had a leak cause he just had a tune up new wires, sparks, etc. His car kept losing horsepower so he had it checked by someone who told him one of his spark plugs had gas on it, all he could do was wait for the spark plug to dry off from all the gas on it. About a couple weeks but I think he had a gas leak fixed to fix the problem so if its not that I dont really know what to tell you...
OuT --> PuReHeLL
http://www.mustangevolution.com/foru...ine=1107000257
PuReHeLL is offline   Reply With Quote
Old 09-03-2003, 10:39 AM   #8
Rick0636's Avatar
Just as a new plug can be bad, so can a new plug wire, one of those could be bad, what I was going to say was check and make sure that they are all hooked up good, I have had one that was not hooked good to a plug, hooking it up properly usually does wonders. lol.
V6 Loss of horse power wyatt-00' Pre-2005 V6 Mustang 19 01-27-2010 09:29 AM
Exhaust leak... Loss of power and MPG? Sxynerd 1996-2004 Mustang GT 7 03-01-2008 08:08 AM
Loss power and overheat, jerking, please help!!! kevpar07 Pre-2005 V6 Mustang 4 09-08-2007 11:25 PM
93 POWER LOSS jcori3 1979-1995 Mustang GT 17 09-19-2006 07:41 AM
oil change. alignment. loss of power Dark02Pony Pre-2005 V6 Mustang 19 10-21-2005 11:39 PM
02:04 AM
