problem - Mustang Evolution
Old 10-14-2009, 07:48 PM   #1
problem
Ok so this has been going on for quite some time. When Im driving down the road and punch the gas, this is gonna sound kinda wierd, but it feels like my car is doing the wave. Im not sure really how to describe it but it feels as if my rear end was going to fall out. Its even worse when im in high rpm then switch gears. I had a local shop put it on the lift to see if anything visibal was wrong, but nothing. Like I said its hard to describe, it just feels like my suspension is like jello...anybody have a clue? thanks
mustang9403 is offline   Reply With Quote
Old 10-14-2009, 09:51 PM   #2
outlawfrog's Avatar
Re: problem
umm.....u checked for a warped rim?
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 10-15-2009, 12:55 AM   #3
Send a message via AIM to dtbback
Re: problem
check your shocks and then your connecting rod bushings for the rear.
dtbback is offline   Reply With Quote
Old 10-15-2009, 08:36 AM   #4
Re: problem
the rear end wiggles some~ but shouldnt to bad (all rubber bushings) you can check your upper and lower control arms to make sure they are bolted on good, then wiggle your tires up and down and to the side (with the car jaked up) and make sure its all good but you dont have a ball join back there~ just to make sure your axle bearings are not hosed up at the wheel.
Old 10-15-2009, 06:03 PM   #5
Re: problem
I dont think its a warped rim..and ive wiggled the tires as youve said spector. Id really hate to have to take it the the dealership..but i guess thats my last resort
Old 10-15-2009, 07:44 PM   #6
67mustang97's Avatar
Region: Vermont
Re: problem
How many miles does it have? I'd check the bushings like Spectorv suggested. Maybe check out your tires for broken belts. My friend has a 96 Cobra that does a similar thing when he hits a bump. We have to replace his quad shocks, we are going to do a control arm swap at the same time.
Old 10-16-2009, 06:30 AM   #7
Zebs5408's Avatar
Re: problem
sounds like shocks to me
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 10-22-2009, 03:35 PM   #8
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Re: problem
check your tire pressure
00STANG00 is offline   Reply With Quote
97 A/C problem phaw16 1996-2004 Mustang GT 7 07-20-2009 01:39 PM
a/c problem 02MustangV6 Pre-2005 V6 Mustang 0 12-26-2006 03:44 PM
Problem.. lowflyn Pre-2005 V6 Mustang 15 07-25-2005 01:52 PM
12:41 AM
