11s, need a cage? - Mustang Evolution
Old 08-17-2005, 09:08 PM   #1
Monkey's Avatar
11s, need a cage?
what is the website for all the rules at the track?
I know 13.99 or faster needs a helmet
I am expect to run about a 12.3 right now, what else would I need?
Old 08-17-2005, 09:40 PM   #2
slvr2000stang's Avatar
Re: 11s, need a cage?
Depends on what sanctioning body the track goes with...
IHRA NHRA etc.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-17-2005, 10:06 PM   #3
Monkey's Avatar
ok. just found the track's website. they say 11.49 faster you need a rollbar and 10.99 you need a cage.
thanks
but I don't want to run an 11.49 or faster.
-race jacket
-roll bar
-3" racing harnesses
-driveshaft loops
forget that. I'll just get kicked out
Old 08-17-2005, 10:31 PM   #4
You can probably make 2 passes then they will throw you out.
2000 Vert 4R70W
Old 08-20-2005, 07:14 PM   #5
All depends on where ya run. Pretty much all the tracks down here dont care. Our local 1/8th mile track dont even make you wear a seat belt....no matter what you are running.
The closest 1/4 mile track here requires a seat belt and a helmet if you're in the 13s I think.
Car: black 1993 Mustang Notchback
Engine: 351w, small cam, Holley 650db carb, stealth intake, AFR185s, Crane 1.6 RR's
Tranny: C4 w/ BTE converter, hardened input shaft, and full manual reverse valvebody
Chassis: Eibach drag launch kit and X2C lower control arms
Times pending
mrpburke is offline   Reply With Quote
Old 08-20-2005, 10:37 PM   #6
MonteCitan's Avatar
can you run 11s on 330 HP?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 08-20-2005, 11:35 PM   #7
Monkey's Avatar
Nah. I haven't gone to the track yet, but I theretically I should be at a 12.3ish based on what others are running with the same mods. The dyno I use is a mustang dyno, which reads low. It's about 350 on a dynojet. It takes about 360-370whp on the dyno I use to run 11s.
It's not just hp that lets you run 11s and whatnot. A 330whp evo is about equivilant to a 600rwhp cobra. I have seen plenty of races where a 300-350whp evo is staying with and passing a 550-650rwhp cobra. (seen quite a few with different cars, so it's the car, not the drivers). It just has to do with weight and gearing and aerodynamics and redline, etc. But for my car, it only takes about 380 with a pretty good driver. Don't forget the awd vs. rwd. I can get 1.6x 60's, where a cobra can get 1.8s or so. 1 tenth in the 60' is equal to 2 tenths in the 1/4.
mrpburke - the drag stip here is used by NHRA and all that high end competitive stuff. They check everything
Old 08-21-2005, 08:45 PM   #8
You need a drive safety loop if you plan on running sticky tires ,also 11.49and lower you need a ,SFI Flex plate or flywheel,6 point roll bar and an aftermarket bellhousing .
GT-Eater is offline   Reply With Quote
Old 08-21-2005, 09:56 PM   #9
Monkey's Avatar
I have awd, it will be street tires. Won't be able to spin them
Old 08-25-2005, 09:04 AM   #10
fast64's Avatar
are you saying a 330whp evo runs in the low 12s, and its faster than a 600rwhp cobra? I haven't been to the races in a while, but last time I checked, Cobras in the 470-500rwhp range were clicking off 11.4s-11.7s.
GO BRAVES
Old 08-25-2005, 03:43 PM   #11
Monkey's Avatar
not around here. my evo keeps up with 500+ rwhp cobras on the highway
Old 08-25-2005, 09:38 PM   #12
fast64's Avatar
there is a huge difference between highway fun and a real track.....
GO BRAVES
Old 08-25-2005, 10:12 PM   #13
Monkey's Avatar
well, i'll get them off the line too
it doesnt really matter though. This thread needs to be closed. My question was answered
Roll cage and struts monstermustang 1996-2004 Mustang GT 8 04-13-2009 10:47 PM
Roll Cage Install jwyche 1979-1995 Mustang GT 26 03-19-2007 09:29 AM
Getting cage put in soon! 91GTstroked 1979-1995 Mustang GT 3 01-11-2007 09:27 AM
You don't need a roll cage in a 14 second car JROC Pictures and Videos 8 12-24-2006 09:46 AM
Mods to get a 5.0 in the 11s Matt@StangMods 1979-1995 Mustang GT 25 04-27-2005 07:16 PM
10:34 AM
