Axle swap - Mustang Evolution
Old 10-18-2009, 08:47 AM   #1
67mustang97's Avatar
Region: Vermont
Axle swap
Would the stock axles out of a 02 GT fit in a 97 with the 7.5? Are the GT axles that much stronger than the ones in the V6, would it be worth the time to swap them out?
Old 10-18-2009, 10:52 AM   #2
Re: Axle swap
I believe the 94-98 mustangs were shorter in length than the 99-04's. In stock form, both Gt's and v6's have 28 spline axles, but I think the axle length would be an issue.
If you're really going to be putting down some serious power and want something stronger, I'd look into some forged axles...they're strong as hell. Though I've only seen them in 31 spline form for the v8 mustangs.
Old 10-18-2009, 05:10 PM   #3
OsirisGuy's Avatar
Re: Axle swap
Also if you are making serious power then you will really want to upgrade from the 7.5" to the 8.8" since the 7.5" is pretty weak and has been known to fail. Besides, this way if you go with the 8.8" you can upgrade the whole rear end and go with the 31 spline.
I also want to say that either the axles between V6 and GT (although both have the same number of splines) or SN95 and New Edge are different.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-19-2009, 12:59 PM   #4
The Darkside's Avatar
Re: Axle swap
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 10-19-2009, 03:55 PM   #5
Re: Axle swap
As far as I know the 7.5in axles and the 8.8in axles are both 28 spline and identical. The year difference from 98 to 99 made the 99+ longer but otherwise the same. Personally as said above if you need to do work on the 7.5 upgrade to an 8.8 if at all possible.
axle question!!!!!!!! ryanxstang Pre-2005 V6 Mustang 5 10-02-2007 09:55 AM
Need Axle 8.8 off 99-04 GT TafoyaMNAA Mustang Parts for Sale and Wanted 5 07-19-2007 08:36 PM
Axle Shafts? Fast93Coupe 1979-1995 Mustang GT 2 05-10-2006 05:05 PM
swap solid axle for irs rar1955 Mustang Parts for Sale and Wanted 6 02-03-2006 08:31 AM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
08:06 PM
