Trying to run 14.5 - Mustang Evolution
Old 08-21-2005, 11:15 AM   #1
Trying to run 14.5
I have a 5 speed 3.8 V6 mustang with dual flowmasters and a bbk cold air intake. I'm aiming for a 14.5 quarter mile time. What should I get next to be able to do that? Thanks. -Chris
cms09071987 is offline   Reply With Quote
Old 08-21-2005, 11:31 AM   #2
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Trying to run 14.5
gears,t-lok,tuner...
I_luv_HP&trq is offline   Reply With Quote
Old 08-21-2005, 01:11 PM   #3
What year is your car?
Cause if you have a 94-98 it will take more than gears and a tune... alot more and even on a 99+ it will take more.
Old 08-21-2005, 01:29 PM   #4
Its an 03
Old 08-21-2005, 01:45 PM   #5
Start with 3.73-4.10 Gears I would do 4.10 gears with a t-lok even with a 5-speed personally.
After you get the gears in buy a speedcal to correct your speedo (dont know if a chip will fix a 99+ 5 Speed speedo)
Get an Aluminum Driveshaft, sticky tires, Underdrive Pulley, and a 600-700 Dollar Nitrous kit and spray a 50 shot. Your motor will handle that with a breeze.
^ Cheapest way right there.
Old 08-21-2005, 05:19 PM   #6
97Stallion's Avatar
yeah, NO2 is defiantely the cheapest way for sure, but it's so addicting that it becomes very expensive and fast. I personally like the N/A route, but that's expensive all at once. But the power is always there and the only thing you have to refill is your gas tank. At $40 a pop now.
Living one day at a time!
Old 08-21-2005, 06:40 PM   #7
slvr2000stang's Avatar
Chip will fix a 99+ 5spd
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-21-2005, 06:50 PM   #8
Ok thanks, then get the chip since you will need one with the nitrous if that is the path you go.
Old 08-21-2005, 07:17 PM   #9
Tbird232ci's Avatar
aluminum driveshaft doesnt make much difference in the 1/4
Old 08-21-2005, 10:55 PM   #10
01mineralgrey6's Avatar
and i'd be carefull with the sticky tires on a 7.5 rear end...though some have handled it in the past.
-Tony
'99 cobra 'vert
Old 08-23-2005, 05:24 PM   #11
I have a 99 up adn with all my mods i would be good to do a 14.7~
3.73 gears
Tlok
UD pulley
CAI
Aluminum DS
Tune
Traction
and you might be CLOSE once you get to where you can hook up and drive good.... but even with all that I still doubt you will hit your mark.
Keep in mind, where you are located at in the US via elevation is a big factor in what you can run as well.
Old 08-25-2005, 03:39 PM   #12
Send a message via AIM to tedness
whats better? low elevation i assume?
tedness is offline   Reply With Quote
Old 08-25-2005, 04:56 PM   #13
97Stallion's Avatar
Yes, lower is better. Their is less O2 at higher elevatoins and the atmospheric pressure is greater at lower elevatoins.
It won't run upton7 1996-2004 Mustang GT 5 05-21-2009 08:55 PM
what should i run? 07stang General Mustang Discussion 26 03-11-2009 07:50 PM
Had a run-in with a GT... MarkuzLS1 The Bar 15 03-01-2007 09:01 PM
run in with 5.0 lx a00v6stang The Bar 23 01-02-2006 06:52 PM
Had a run it with a '02 GT Scoot99V6Stang The Bar 33 12-11-2005 03:24 AM
10:47 AM
