Gear and axle swap questions. - Mustang Evolution
Old 08-24-2005, 10:43 PM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I'm going to hopefully start getting things together to start my turbo project about this time next year and wanted to get a few things I'll need in advance...
I have an automatic and I know it's recommended to get the next size gears up over a manual (3.73 for manual, 4.10 for automatic) but I've also heard that if your gear ratio is fairly high, once you turbo or supercharge your car, that you'll run out of gear at top end. I also don't like how bigger gears lower your top speed, so I've been considering just getting 3.55 gears because I want a little bang just from that and I want to plan ahead for the turbo. So, I guess what I'm asking for is everyone's input on what gear size I should get. Also, I plan on about 350 hp, maybe a little less, and wonder if I'll need to get an 8.8 axle for it or if a T-Lock would be good enough.
Additionally, I've seen on ebay and in magazines a "Ring and pinion set" and wonder if this all I would need to do the gear swap,(btw I have a SCT tuner and wonder if that would work to fix the speedo) and if not please tell me what else I'll need. As for the axle I've seen the 2 axle pieces on ebay for pretty cheap and wonder if just those 2 pieces is all I need for that, or if I need anything for the differential or..er..I really have no idea on that!?
Thanks in advace.
DarkShadow is offline   Reply With Quote
Old 08-25-2005, 06:23 AM   #2
Re: Gear and axle swap questions.
If you are going to turbo, go ahead and jump up to the the 8.8 rear and 3.55's in that. The stock one might handle it, but it would be well worth the cost after you look at how much gears and a t-lok are just for the 7.5. When you change the gears, I believe you'll be able to fix the speedo using the SCT tuner. And also, when you look around for an 8.8....just buy one that already has axles on it.
Old 08-25-2005, 06:36 AM   #3
slvr2000stang's Avatar
Yes his SCT tuner will make the change for different gears.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-25-2005, 07:38 AM   #4
I liek gramer
WhiteStang99's Avatar
Sweeeeeet. A turbo project in AL near me.
Old 08-25-2005, 12:36 PM   #5
Go with 3.73 atleast not 3.55
Old 08-25-2005, 08:41 PM   #6
Send a message via AIM to blownsix
ye im blown and im goin 4.10s
http://i23.photobucket.com/albums/b3.../99stangz2.jpg
Suspension: Bullitt 8.8, Steeda G Trac Bar, Front and Rear swaybar delete, Lakewood 90/10 Struts, Lakewood 50/50 Shocks, UPR Pro-Series Ultra-Light Weight Competition LCA
Performance: Vortech V1, Mac Long Tube Headers, Mac O/R H pipe, 80MM Lightning MAF, GT Take offs Tuned By Doug at Bamachips, 4.10s
Interior: Autometer Phantom gauges Boost, Water Temp, A/F, Dual pillar gauge Pod, Gagueg Bezel,
Styling: Mach 1 Grill Delete Kit, GT hood scoop, Smoked Headlight and Taillight blackouts, taillight sequencers kit
blownsix is offline   Reply With Quote
Old 08-25-2005, 10:03 PM   #7
DarkShadow's Avatar
Don't you end up running out of gear at topend tho? And I don't like how bigger gears lower top speed ...um...and I've even heard that the stock gears will do just fine...I'm confused..I don't know what to do...WWWAAAHHH!!!!
Old 08-27-2005, 12:30 AM   #8
How built is your car gonna be? If you are just adding a litte bit of power, 4.10's or 3.73's will do you best. There's really no reason to be running over 120 anyway...not like you're gonna top that in the quarter anytime soon. If you're gonna be pushing like 450 or more hp....yes...I would recommend going with a lower gear such as the stocks or something around that.
Old 08-27-2005, 10:21 AM   #9
Tbird232ci's Avatar
i have a turbo thunderbird, came factory with 3.55's, and ive had the car up to about 135, plenty of RPMs left, still pulling
go ahead and get some 3.73's in it, you wont run out of gear untill probably 135-140, and most street cars never see those speeds
as for your turbo setup, what size turbo(s) do you plan on running?
Old 08-27-2005, 01:41 PM   #10
You should come down sometime, in in Rogersville/killen alabama which is like 20 min from athens....
I also know some VERY good mechanics in the area if you need any help or a second opinion on labor prices.
As far as gears I would go 3.73 gears, that should be fine. You can buy a 8.8 rear with the gears ready to go, minus axles. The cost has went up, as it was 725... not its more but still worth it. Building a 7.5 is fine but when you turbo it.... it will break soon. I can also help you install it, if im free.. its an easy install really just takes a little time.
Its better to spend the mony on an 8.8 than to rebuild the 7.5 a couple times, and a gear install is pricy and can be done bad (but for local people I know a very good installer that does it for under 200 bucks )
Old 08-30-2005, 11:28 AM   #11
DarkShadow's Avatar
Sweet, I could definately use your help on this. I know Rogersville pretty well, used to live off of Snake road, and I clean a pool out in Elgin. I'll definately need to throw a bunch of questions at you about where to get stuff done and just personal opinion on stuff.
I'm planning on 350rwhp with the turbo, and a final number when all is said at 400rwhp. The set up I want is the race kit w/intercooler at tmaturbo.com
Old 08-30-2005, 03:18 PM   #12
Buy a ready to install 8.8 with 3.73s (minus axles and brakes is ok)
Old 09-04-2005, 10:43 AM   #13
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
just look at the 00 cobra r..it has 3.55's, 375hp, and tops out at a little over 175mph...so 3.73's would probly be better unless you plan on doing 170 often
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 09-05-2005, 05:48 AM   #14
It also has a 6 speed tranny which makes a difference.
Old 09-05-2005, 09:04 PM   #15
DarkShadow's Avatar
Old 09-07-2005, 02:18 AM   #16
3.73 will be fine.
You building up the engine or just slapping something on? Cause if your just slapping it on you better plan for a engine rebuild soon, and you better get it dyno tuned
shifting into gear, axle noise audio75 Pre-2005 V6 Mustang 9 07-18-2010 11:08 PM
Axle swap 67mustang97 Pre-2005 V6 Mustang 4 10-19-2009 03:55 PM
94 V6 Gear Swap?? (5spd Car) jimmyjams Pre-2005 V6 Mustang 1 04-23-2008 10:34 PM
8.8 axle conversion questions Horse Pre-2005 V6 Mustang 9 09-09-2007 08:53 AM
gear questions Kyle Pre-2005 V6 Mustang 42 03-29-2007 09:37 PM
09:54 PM
