shocks/struts/springs etc. - Mustang Evolution
Old 08-26-2005, 04:38 PM   #1
01mineralgrey6's Avatar
well, i balanced my wheels today at work and was looking at the treadwear on the front tires and they are starting to cup. so its time for some suspension stuff, where would be the best place to get "C" springs from, also i have heard that lowered 99-04 mustangs need fox shocks and struts. is that right? and probably get a decent set of CC plates, if i need them, or should i wait for the springs to settle first? thanks!
-Tony
'99 cobra 'vert
Old 08-26-2005, 09:12 PM   #2
Re: shocks/struts/springs etc.
I bought my whole suspension from rob at rdmotorsport.com, or 97stallion on the site. Great customer service, great prices. BTW, I bought the bullit suspension kit, steeda monochromy subframes, and mm c/c plates.
Old 08-27-2005, 10:26 AM   #3
Tbird232ci's Avatar
why would you need fox shocks and struts? if you get a good set of shocks and struts for your car, they are designed with lowering in mind, so you dont need fox parts
Old 08-27-2005, 01:38 PM   #4
if you drop more than 1.5 inches you can run fox struts/shocks (probably less than that... but no point in using fox struts/shocks unless you aer 1.5 or so~)
I would stick with 650+ front rate springs and 250-300+ rear~ The C springs fall into this area and are cheap. They dont drop a ton... more like 1.1 inches if you dont tinker with them (cutting the rear is mandatory if you want an even drop)
I would go with H&R's if i was you and wanted more than 1.1 inch drop, which ever brand make sure they have a good rate.
For shocks and struts... I would go bilstein or mach1 tokicos. For CC plates, 4 bolt mm versions are very nice and have a lifetime warranty, and offer nearly twice the adjustment of almost all other CC plates on the market.
Old 08-27-2005, 07:51 PM   #5
Thanks for the info, i think ill probably just get C springs...isn't that what you have Brandon? I by no means want it too low, just enough. Ill have to go check out robs site tonight
-Tony
'99 cobra 'vert
Old 08-27-2005, 11:33 PM   #6
Send a message via AIM to charkelly9
what did this cost... im looking into the same excate set up
charkelly9 is offline   Reply With Quote
Old 08-27-2005, 11:45 PM   #7
http://www.rdmotorsport.com/4.6%20V8...46Suspack.html
-Tony
'99 cobra 'vert
Old 08-28-2005, 12:35 AM   #8
anyone heard anything about tokicos springs??? found a shock/strut/ spring package for just under $400.
would i be able to get away with mach 1 tokico shocks/struts with H&R super sports? i found out where i read that lowered mustangs need fox s/s too, it was on MMs website.
-Tony
'99 cobra 'vert
Old 08-28-2005, 12:53 AM   #9
the tokico kit lowers about 1.5 inches, and i also found out that tokico is a division of koni... wonder who makes the springs for them though, and what kind of springrate :chin:
-Tony
'99 cobra 'vert
Old 09-05-2005, 10:42 PM   #10
97Stallion's Avatar
Just so you know I'm redoing the whole site again. Prices are going to be changing as well. Like the MM C&C plates are going for 195 shipped. That's an everyday price. And the bullitt pedals are 50 shipped everyday as well.
Living one day at a time!
Old 09-06-2005, 03:51 PM   #11
:chin:
-Tony
'99 cobra 'vert
Struts and Shocks xcxm049 Pre-2005 V6 Mustang 11 03-05-2010 12:59 PM
shocks, struts, and springs on a 79 notch Taywi Classic Mustangs 8 03-13-2007 11:41 AM
shocks/struts with c springs electricstang Pre-2005 V6 Mustang 16 06-30-2006 10:42 PM
c-springs & mm plates....ok w/o shocks struts? tedness Pre-2005 V6 Mustang 4 06-27-2005 11:03 PM
Shocks and Struts with springs? steedav6builder Pre-2005 V6 Mustang 16 07-13-2004 09:42 AM
05:10 PM
