need help asap - Mustang Evolution
Old 08-26-2005, 07:23 PM   #1
need help asap
well i am trying to do udp install i took off the belt and now trying to remove the the factory pull.I attach the pulle remover to the pull how far is the center bolt on the puller supposed to go in all the way or what i keep hearing craking and dont know why i hope the just means it loosing and not striping any thing
reaper4stang is offline   Reply With Quote
Old 08-26-2005, 07:27 PM   #2
slvr2000stang's Avatar
Re: need help asap
There should be a conical point on the puller so it does not touch the threads in the crank.
Did you remove the bolt that holds the balancer on?
I am guessing your car is a 99+????
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-26-2005, 07:31 PM   #3
Re: need help asap
i am using this but the factory pullie is still on that's ok right,the center bolt is turn all the way to the duck foot or is that to far (or is that too far)
Old 08-26-2005, 07:33 PM   #4
Re: need help asap
I believe I had the duck foot as snug to the stock pulley as I could, then turned the center bolt to start backing it off the crank.
2000 Vert 4R70W
Old 08-26-2005, 07:35 PM   #5
Re: need help asap
it should look like your pic but with the stock pulley still there.
2000 Vert 4R70W
Old 08-26-2005, 07:36 PM   #6
Re: need help asap
yes i removed the one center bolt but cant get off the factoy pully
Old 08-26-2005, 07:37 PM   #7
Re: need help asap
yes same as pic but pullies still there
Old 08-26-2005, 07:49 PM   #8
Re: need help asap
Here is an example.
2000 Vert 4R70W
Old 08-26-2005, 08:05 PM   #9
Re: need help asap
**** are you supposed to leave the bolt in before you put on the pully
Old 08-26-2005, 08:10 PM   #10
Re: need help asap
bolt through ducks foot then attach ducks foot to pulley with the 3 bolts, then start turning the center bolt to remove the balancer & pulley.
Here is an excellent how-to.
http://www.miracerros.com/mustang/pulley.htm
2000 Vert 4R70W
Old 08-27-2005, 01:53 PM   #11
Re: need help asap
dont you loosten the bolt a bit then put the puller on it and the force applied to the bolt pulls the balancer and pully out, just make sure the bolt has slack in it else the head of the bolt will meed the balancer and it wont go no where.
Old 08-27-2005, 03:38 PM   #12
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: need help asap
all i have to say is be careful. i remember it was a pain when i did this like a year ago. i accidentally cracked the stock pulley. take your time to do it right.
good luck
I_luv_HP&trq is offline   Reply With Quote
Old 08-27-2005, 03:45 PM   #13
Re: need help asap
also... make SURE you tq the pulley to 125 ftlbs... i didnt get mine tight enough and it triggered a CEL light multiple misfiring.... so tq it down with a tq wrench not just an impact gun.
Old 08-27-2005, 05:47 PM   #14
Kiljosh's Avatar
Re: need help asap
Torque it with the belt on so it doesn't spin, incase you didn't figure it out on your own.
You can also lock the engine in place at the flywheel if you remove the starter.
Old 08-27-2005, 07:19 PM   #15
Re: need help asap
Which bolt are you referring to?
You remove the crank bolt then attach the pulley remover.
2000 Vert 4R70W
Old 08-28-2005, 11:11 AM   #16
Re: need help asap
whoo hoo it's finally done now,with a couple of cut knuckle and alot of pissed off thought's at ford.
Thanks to all you guys
Old 08-28-2005, 12:30 PM   #17
Re: need help asap
Good to hear.
2000 Vert 4R70W
Need help asap buddykern 1996-2004 Mustang GT 18 11-25-2009 06:52 PM
NEED HELP ASAP!!!!!!!! sledgehammer Pre-2005 V6 Mustang 4 03-29-2008 08:57 PM
Need help asap Brent Pre-2005 V6 Mustang 7 05-22-2005 08:53 AM
Help Asap Please!! douGT 1996-2004 Mustang GT 2 05-17-2005 08:21 PM
need help asap!!! Monkey Pre-2005 V6 Mustang 17 06-20-2004 11:24 PM
03:39 AM
