engine swap - Mustang Evolution
Old 10-22-2009, 10:45 AM   #1
engine swap
i have a 1999 mustang with a 3.8 i found a v6 engine from a 2006 mustang are these interchangable.......thanks
midnightrider_s is offline   Reply With Quote
Old 10-22-2009, 10:49 AM   #2
Re: engine swap
It can be done, however they are not the same engine. The 2006 is a 4L and is a good bit different than the 3.8 you currently have.
You would need to do a lot to your car to make it work. The 2006 is also a drive by wire, not a drive by cable. So, you'd have to mess around with your gas pedal configuration as well, or make some sort of mechanical throttle body deal to work with the motor.
In short, I'd look for another V6 motor.
Engine swap 3.8L to 4.6L NEED HELP!!!! PonDog15 Pre-2005 V6 Mustang 23 06-29-2010 09:43 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 02:59 PM
Want to swap my v6 engine for a v8 Justin-Heath Pre-2005 V6 Mustang 10 12-08-2006 04:56 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 03:01 PM
engine swap evilweirdo42 Pre-2005 V6 Mustang 26 11-23-2004 08:21 PM
06:35 PM
