clutch is screeeeaming! - Mustang Evolution
Old 10-22-2009, 04:42 PM   #1
Ok so on top of my other problem..last night when on the way home, my clutch starts making some loud screaming noises. It still grabs every gear, just when I push it in, it sounds and feels like metal on metal..Im taking it to the shop in the morning, but doesnt anyone know what kind of problems I might be looking at? thanks again
mustang9403 is offline   Reply With Quote
Old 10-22-2009, 04:54 PM   #2
67mustang97's Avatar
Region: Vermont
Re: clutch is screeeeaming!
Possibly the throw out bearing.
Old 10-23-2009, 12:36 PM   #3
throwout/pilot bearing. They are both cheap parts... its getting to them thats an issue.
On 99-04 v5s the transmission unbolts from the bellhousing on the outside so its pretty easy to remove the transmission then the bellhousing in two parts~ just fyi not a big deal.
If you are in there REPLACE the following
clutch/pressure plate
resurface flywheel
pilot bearing
throwout bearing
inspect pivot ball stud and fork arm replace if any wear sign
inspect bearing retainer sleeve (what throwout slides on)
the stock clutch in 99+ v6s is quite strong so unless you plan to have 300rwhp or more soon the stock one will do just fine.
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 11:19 AM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 11:54 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 04:00 PM
04:39 AM
