Injector questions... - Mustang Evolution
Old 09-02-2005, 09:27 PM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
...um...I was looking at some #39 cobra injectors on ebay when it occured to me....do I need adapters for them to fit on my car? I don't know! Somebody help I'm a flaming newb to the world of injectors!!!!!!!!!!
DarkShadow is offline   Reply With Quote
Old 09-02-2005, 09:52 PM   #2
Re: Injector questions...
you should just go to www.vmptuning.com and get some. you can get some 42# injectors for about $275 with the right connector.
bigpomps is offline   Reply With Quote
Old 09-02-2005, 09:58 PM   #3
DarkShadow's Avatar
Well I looked there, but I can get these injectors for $160 bucks! So do I need adapters or can I get them to fit right on? Even if I do need injector adapters it would still be cheaper this way...
Old 09-03-2005, 07:54 AM   #4
i dont belive you do... but you never know what they will alter... I do know the coil design is no where near the same.... hmmmmmm
Old 09-03-2005, 04:29 PM   #5
DarkShadow's Avatar
Dun da da dun...Knowledge Boy where are you? We need you!
Old 09-05-2005, 07:16 AM   #6
Danger Dude's Avatar
No you dont need adapters. 99+ V6 mustangs use pencil type injectors and are interchangable. If you had a pre 99 you would need adapters
Old 09-05-2005, 09:05 PM   #7
DarkShadow's Avatar
SWEET!!!!!!!!! 'Cause I just bought a set of 8 (even tho I don't need 8) with only 2,300 miles on 'em for $165 with shipping!
Old 01-24-2006, 06:39 PM   #8
Good buy, not to be a cocky bastard but the ones at vmp are 42lbs. I still think you got a good buy though.
ProCharger Sticker/Decal Logo
Old 01-24-2006, 07:02 PM   #9
DarkShadow's Avatar
Ford rates them for 39#, but they have been proven to actually flow like 42#'ers. I've done quite a bit of research since this thread.
Old 01-24-2006, 11:37 PM   #10
Nice buy
Old 01-26-2006, 06:25 PM   #11
Tbird232ci's Avatar
If they flowed like 42# injectors...they wouldnt be 39# injectors
if you increase your base pressure maybe
Old 01-26-2006, 09:36 PM   #12
DarkShadow's Avatar
All I know is what dynotuners have seen and what happens when they flow match injectors for which ones flow the absolute closest to keep one from running excessively leaner than the rest.
Maybe Ford rates there's differently from most. What Ford comes with "42# injectors" anyway? Is there one? Maybe the massive v10 trucks, but they probably have bigger ones. So where do they get "42#" ones? I believe all the 42# injectors you see are offered by companies not affiliated with Ford even though they are offered for Ford vehicles (like VMP). I'm sure they prefer saying 42# as opposed to Ford's idea of supposed 39#...
Old 05-14-2006, 01:12 PM   #13
There are EV-1 injectors and EV-6 injectors. Those 39 pounders won't work on your car without the adaptor harness. Youre better off getting some 36#'s or some 42#'s. You may have gotten the 39's for cheap, but, now you need the $150.00 adaptor kit to make them work on a pre-03/04 engine.
Yellow98SVT is offline   Reply With Quote
Old 05-14-2006, 08:56 PM   #14
DarkShadow's Avatar
My God where did this come from?
That's the second time this thread has come up from the dead.
BTW, these injectors have been working just fine in the motor for a couple months now with no harnesses. Dates own you and I have a `04 with pencil injectors so it was a direct "plug and play".
And for the last time, Ford 39# flow like 42#.
Old 05-15-2006, 09:45 AM   #15
what hp range are 39s good for (dead thread ftw)
Old 05-15-2006, 03:21 PM   #16
DarkShadow's Avatar
I don't remember for sure, but they'll go a lot further with 8 like you have than with only 6 like what I have.
Old 05-23-2006, 07:09 AM   #17
Originally Posted by Danger Dude
No you dont need adapters. all 99+ mustangs use pencil type injectors and are interchangable. If you had a pre 99 you would need adapters
The 99-04 GTs still use a fat injector with a rectangular connector (not oval like the V6).
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 05-23-2006, 07:09 AM   #18
Maybe 39lb is only at 39psi and every other ford injector is rated at 42.5psi (3bar, the standard).
Justin Starkey
Old 05-23-2006, 07:10 AM   #19
You got it wrong too. Old style 36s or 42s would require adapters.
Justin Starkey
Old 05-23-2006, 05:11 PM   #20
Sorry you are correct!!!! I edited my post
injector size.... help!!! svtlx 1979-1995 Mustang GT 5 04-18-2009 06:07 PM
Fuel Injector Rating RetroTA 2005-2010 Mustang GT 2 08-16-2006 01:36 PM
Fuel injector how to's? DarkShadow Pre-2005 V6 Mustang 4 03-08-2006 08:41 PM
Questions cms09071987 Pre-2005 V6 Mustang 14 06-26-2005 12:28 PM
gt take-off questions blk2kconvstang Pre-2005 V6 Mustang 7 03-22-2004 08:02 AM
06:37 AM
