improving gas mileage on my 2003 v6 mustang - Mustang Evolution
Old 09-03-2005, 08:30 PM   #1
Send a message via AIM to whitev6stang03 Send a message via MSN to whitev6stang03 Send a message via Yahoo to whitev6stang03
hey guys, i was just wondering about how to improve my gas mileage? So far i know, installing duals, CAI, and a chip can improve my mileage maybe not much but something is better that pay 3 bucks a gallon!!! So is there anymore bolt on's or tips out there that could give me more miles to the gallon?
whitev6stang03 is offline   Reply With Quote
Old 09-03-2005, 09:38 PM   #2
I liek gramer
WhiteStang99's Avatar
Re: improving gas mileage on my 2003 v6 mustang
Someone suggested in another thread placing a wooden block under your gas pedal.
I'm inclined to believe that it will work.
Old 09-03-2005, 09:55 PM   #3
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
i don't believe in some of that crap. if a CAI is suppose to improve performance how does it improve mileage? any mods to make it faster is just working your car more or allowing more airflow which in turn uses more fuel...(correct me if i'm wrong) However the chip may help if it's at the right setting (better spark) and you're driving like an old lady. and don't go out and buy one of those stupid tornado things to put in your air intake that add 35 HP and 5 MPG. that stuff doesn't work, it just sells.
Just keep all the fluids changed regularly, tire pressure where it's suppose to be at, a clean fuel system, good ignition system, working o2 sensors, steady flow of gas if you're on the freeway and all the other common sense stuff.
I_luv_HP&trq is offline   Reply With Quote
Old 09-04-2005, 07:27 AM   #4
jimmy_beaner's Avatar
Region: Iowa
I get 30 mpg with duals and CAI. I have no mufflers. I also get this on the interstate... and I drive like a fool in the city sometimes though, so I don't know what I'm gonna get.
Old 09-05-2005, 03:09 PM   #5
97Stallion's Avatar
Not hot rodding your car will definately save gas!!! Also that wood trick REALLY works!! An UDP will help a little too since it slows all your accessories down, and don't use the AC, that helps too.
Living one day at a time!
Old 09-05-2005, 03:45 PM   #6
I liek gramer
Don't use the AC in the city at least. Rockin out with the windows down is cheapest in the city, and AC is cheapest on the interstate or highway.
Old 09-05-2005, 04:58 PM   #7
97Stallion's Avatar
Actually i would say suffering with the windows rolled up and no AC is the cheapest.
Old 09-05-2005, 05:03 PM   #8
I liek gramer
OK, you win.
Old 09-05-2005, 05:16 PM   #9
01mineralgrey6's Avatar
i just follow people close.. i think its called drafting :dunno:
j/k
-Tony
'99 cobra 'vert
Old 09-05-2005, 05:28 PM   #10
j/k
That leads to unsightly rock pecks all over the front of a car here.
Old 09-05-2005, 05:45 PM   #11
I liek gramer
or a bullet to the head here.
Old 09-05-2005, 06:43 PM   #12
Kiljosh's Avatar
Lol
Old 09-06-2005, 07:43 AM   #13
Send a message via AIM to tedness
clean your fuel system. did wonders for mine....60k w/ no prior system cleaning.
tedness is offline   Reply With Quote
Old 09-06-2005, 11:24 AM   #14
97Stallion's Avatar
or changing your sparkplugs, all that good "tune-up" stuff does wonders.
Old 09-06-2005, 02:48 PM   #15
doing a tune-up will help alot.....CAI really does give you better gas milage i got 40 more miles out of my tank after i got my CAI on
mrd11387 is offline   Reply With Quote
Old 09-08-2005, 09:21 AM   #16
Kelly's Avatar
Justin has a tune for gas mileage...I got 28+ on the highway from using it and I have an automatic with the mods below..
02 Mustang v6 auto:
4.10 t-lock
Xcal2 tuned by Justin
3200 PI stall
FMS Aluminum DS
RPM P&P upper and lower
RPM GT TB
RPM 207/207 cam
DMM denscharger
GT Takeoffs w/ X-pipe, spintech mufflers, hi flows
MAC ceramic coated LT's
ASP UD crank
13.95 @ 98.15
Kelly is offline   Reply With Quote
Old 09-08-2005, 11:11 AM   #17
I really need to look into one of those multi stage chips, my single tune is a little much at times.
Old 09-09-2005, 08:50 AM   #18
Dom
Dom's Avatar
Send a message via AIM to Dom
So does my friend with a 5.0, he shifts at 1500.
v6 mustang
improving gas milage whitev6stang03 Pre-2005 V6 Mustang 11 02-15-2006 08:04 AM
04:31 AM
