aode dead end? - Mustang Evolution
Old 10-25-2009, 02:18 PM   #1
aode dead end?
New to forum, but long time reader. I currently have a 94 mustang v6 (aode) and the transmission went out. I have a used trans from a 95 mustang v8 (aode). Every thing plugs in and lines up until I snug the transmission bolts at the bellhousing. Then the crank will not spin, and bellhousing is not fully seated. took trans out to make sure the torque conv. is set and it was. Searched the flex plate, torque converter between the v6 and the v8 and are the same part numbers listed at various parts houses. Whats different? didnt find any posts of anyone trying this. Thank you for reading.
mark cr8zy is offline   Reply With Quote
Old 10-25-2009, 03:48 PM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Re: aode dead end?
thats wierd it should of fit if its the same part # samthing might be wrong on the car
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 10-26-2009, 09:53 AM   #3
OsirisGuy's Avatar
Re: aode dead end?
The only thing I could think of would be the (input?) shaft. It might be different between engine models. You could try replacing that, otherwise it should bolt right up.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-26-2009, 05:31 PM   #4
Re: aode dead end?
Ill check that out Os, I cant be the only one to try this swap. There has to be someone that been in this spot? Thank you for your response guys.
Old 10-28-2009, 04:37 AM   #5
Zebs5408's Avatar
Re: aode dead end?
you have my respect! i have never seen anyone do that lol! try goggling it. i searched around for u and didnt find much! good luck man and im glad u finally signed up! youll see these guys will be a life saver in time of need!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 10-29-2009, 10:48 AM   #6
OsirisGuy's Avatar
Re: aode dead end?
I'll see if Haynes says anything but I'm at school right now. If you don't hear a reply within 24 hours either send me a PM or reply here to remind me to check.
OsirisGuy is right
2002 Mustang GT
Old 10-29-2009, 11:54 AM   #7
Re: aode dead end?
I appreciate the leg work.
AODE shifting too early randyrobertson 1979-1995 Mustang GT 2 07-04-2010 01:30 AM
aode problem dbiser 1979-1995 Mustang GT 6 12-30-2007 01:11 PM
95 3.8, aode trans, and black 95 hood FS fast64 Mustang Parts for Sale and Wanted 0 10-09-2004 11:11 AM
AODE and 4R70W? RedDragonV6 Pre-2005 V6 Mustang 3 01-21-2004 06:20 PM
05:15 PM
