Tranny fluid - Mustang Evolution
Old 09-06-2005, 11:33 PM   #1
Tranny fluid
Are there any how to's out there on how to correctly change the trany fluid? It's a 97 auto
97conv6 is offline   Reply With Quote
Old 09-07-2005, 01:52 AM   #2
Re: Tranny fluid
its not fun lol but its pretty easy... just take out the bolts, starting at the end closest to the ground (aka front may be jacked up so rear of the pan. Loosen the back bolts and fluid should start to drain if not keep loosening the bolts around the back side and some on the edges until fluid starts to drain, let it drain. After it has drained then take the pan on off. After this you can replace the filter and put the pan back on after cleaning the seal good to remove debris and crap like that.
After its all back togther fill her up, then you will have to crank the car and cycle though the gears from 1st to drive and reverse etc a few times to get her to start working again. Dont shift fast just leave it in each gear for a couple then go to the next and what not.
Thats how ive always done it, im sure others will chime in.
Old 09-07-2005, 05:44 AM   #3
slvr2000stang's Avatar
Re: Tranny fluid
Btw.
Dropping the pan drains about 1/3 of the fluid, the rest is in the torque convertor & the stock cooler.
It is recomended that the entire system be drained & replaced every 30,000 miles.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 09-07-2005, 07:47 AM   #4
Re: Tranny fluid
How exactly do you get the other 2/3 out of the torgue converter and cooler???
Old 09-07-2005, 01:37 PM   #5
Re: Tranny fluid
Anybody...nobody???
Old 09-07-2005, 01:49 PM   #6
Re: Tranny fluid
From TCCOA.com
There is actually a nut on the Torque Converter - a 1/8-27 dryseal converter drain plug.
When you look underneath the car, there is a rubber grommet on the bottom of the torque converter housing, that pops right off (doesn't seal or anything just keeps debris out of there). Take it out and you will be able to see the TC. Then rotate your TC until you have access to the NUT. That's all.
More info here: http://www.tccoa.com/articles/tranny/index.html#
2000 Vert 4R70W
Old 09-07-2005, 04:00 PM   #7
Re: Tranny fluid
or you can have them flush all the fluid and get the filter changed at jiffy lube.
Old 09-07-2005, 04:51 PM   #8
jimmy_beaner's Avatar
Region: Iowa
Re: Tranny fluid
how much is that? I priced it this summer at some place, and they wanted like $80.
Old 09-07-2005, 06:15 PM   #9
Re: Tranny fluid
Any where from 80 to 120.
But it does change it all
2000 Vert 4R70W
Old 09-07-2005, 06:19 PM   #10
Region: Iowa
Re: Tranny fluid
does it help firm up shifts? my car has 75,000 on it now... and has never had it changed
Old 09-07-2005, 06:30 PM   #11
Re: Tranny fluid
Yeah, IM @ 70K now as well
Old 09-07-2005, 07:42 PM   #12
Re: Tranny fluid
Reccomended change interval is 30k
2000 Vert 4R70W
Old 09-08-2005, 09:52 AM   #13
Re: Tranny fluid
I'm in the process of changing mine now, but hit a snag, I can't find the bolt on the tc. I removed the rubber thing and can see it. is there any easy way to rotate the tc?
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Maybe I Need Blinker Fluid nay's mustang 1979-1995 Mustang GT 6 02-10-2009 04:50 AM
T-5 fluid Mobil 1? eagle05 1979-1995 Mustang GT 6 07-02-2007 09:44 PM
Tranny Fluid decided to boil over... Ibanezplayer272 1979-1995 Mustang GT 10 02-20-2006 07:56 PM
Too much Transmission fluid? Ibanezplayer272 1979-1995 Mustang GT 2 11-27-2004 05:54 PM
09:58 PM
