eaton m90 question - Mustang Evolution
Old 09-10-2005, 09:27 PM   #1
eaton m90 question
i was wondering if i could take the top end off a super coupe and put it on my 99 v6? ive been looking for info on this for a long time and cant find anything. id appreciate any info i can get on it.
VindictiveStang is offline   Reply With Quote
Old 09-11-2005, 02:37 AM   #2
Kiljosh's Avatar
Re: eaton m90 question
Look, Im gonna give it to you straight.
Don't try.
I planned on doing this awhile ago and decided not to and sold the supercharger. If you were going to put an m90 in your car it would be easier to just do an engine swap than to track down all the parts you would need to make it work.
You can only run so much boost with the thing before the crappy stock pistons could possibly give, or the rods, or other problems that could happen.
If your going to do it, get a whole engine from a supercoupe and put it in. They have forged bottom ends and will hold up better than your mustang's stuff. Or just save up and get a pre-made kit from procharger or something. I just don't think this swap is worth the trouble...
Old 09-11-2005, 08:56 AM   #3
This is your best bet
Old 09-11-2005, 08:33 PM   #4
i was afraid of that. how difficult would the engine swap be. also about how much would it cost? thanks
Old 09-11-2005, 11:42 PM   #5
Kiljosh's Avatar
Engine swaps aren't really all that difficult if you have a donor car. Just pull anything you need. It gets annoying when your looking for individual parts and could take a bit of time.
If you were to find a junk engine somewhere and rebuild your prob looking atleast 2 grand paying labor and such.
Old 09-12-2005, 06:48 PM   #6
the supercoupe motor in the end will still fall short or your performance expectations most definatly. Upgrade the heads/cam/intakes for your car and N/A you will put down more power than the supercoup motor. Then do a blower and.... you will definatly have some nice power. With H/C/I you should see 230-240rwhp (for na build) and same in tq~ if you go with a blower may not make as much until you get the blower but after.... a good bit more than ^
Old 09-16-2005, 01:39 PM   #7
Tbird232ci's Avatar
yes, the supercoupe makes about 230hp out of the box
while yes, you can mod them, but there is only so much you can do within a budget, you might be able to get 250-275 at the rear wheels with an intake, exhaust, pulley, and other small things, but once you start to go past that, it gets really expensive
not to mention, you would be going from OBD2 to OBD1, making the car difficult for emmissions, and then getting your chassis harness to mesh with the engine harness would be difficult too
Old 09-16-2005, 05:37 PM   #8
are you sure they put down 230rwhp stock... I really dont see that. I do belive ive seen dynos stock and they are not very impressive.... hummm you never know though.
Old 09-17-2005, 11:37 PM   #9
Tbird232ci's Avatar
not at the wheels, i guess the way i wrote that post, it came out to sound like it
they generally put down about 195ish at the wheels, but in an mn12, it has some crappy IRS, and it saps more power than a stang, so in a stang, it *might* put down 205 at the wheels with a 5-speed
96 eaton m90 swap 96mustang21 Pre-2005 V6 Mustang 16 03-10-2010 11:07 AM
Eaton M90 Supercharger CCT4132 Pre-2005 V6 Mustang 5 09-15-2009 02:46 PM
Eaton M90 SC + Mustang 04 v6 =??? wh!te_stang General Mustang Discussion 19 04-07-2009 09:22 PM
Eaton M90 Supercharger for V6 Mustangs nmaraijko Mustang Parts for Sale and Wanted 10 08-10-2008 05:16 PM
eaton m90 question greenpony02 Pre-2005 V6 Mustang 10 01-23-2005 12:07 PM
06:12 PM
