how much will 3.73's do? - Mustang Evolution
Old 09-12-2005, 07:27 PM   #1
how much would 3.73 gears do on my 2000 v6 with a t-lok? i have a 5-speed and rpm bv heads and a new cam and x-cal 2 with a underdrive pulley and mac cold air intake with drag radials. the best i ran was a 14.2 at 99 mph. just curious if i could hit 13.5 with the gears and t-lok.
bigpomps is offline   Reply With Quote
Old 09-12-2005, 07:35 PM   #2
Re: how much will 3.73's do?
Not sure about that, but you cant go wrong w/ 3.73's on a stick.
2002 Mustang GT, 5-speed, torch red. K&N, 3.73 gears, flowmaster cat back, and lots of love.
1991 5.0 lx conv. auto, black. Full saleen body kit, cold air intake, msd ignition, flowmasters, off road h-pipe, underdrive pulleys, trickflow intake, trickflow stage 1 cam, 190 lph fuel pump, 30 lbs injectors, 73mm mass air.
http://www.mustangevolution.com/gall...0632_thumb.jpg
saleen0027 is offline   Reply With Quote
Old 09-12-2005, 07:41 PM   #3
i know the 3.73's would be perfect on a stick... btw i also have true dual exhaust with mac shortie headers and an offroad x-pipe.
Old 09-12-2005, 08:41 PM   #4
Kiljosh's Avatar
If you still have the stock rear in your car the gears/tlok can knock off almost a second if I am not mistaken.
And yes, 3.73's are what everyone reccomends for 5 speed.
Old 09-13-2005, 09:02 AM   #5
Zim
You want to **** me?
Zim's Avatar
Being a 2000 you already have 3.27's so a 3.73 isnt a huge upgrade. Personally Id go with 4.10s, itll probably knock about .5 second off your 1/4.
I like toys
Old 09-13-2005, 05:36 PM   #6
i thought that all v6's had 2.73's in the rear. i thought only the gt's had the 3.27's.
Old 09-13-2005, 06:03 PM   #7
expect 2.5 tenths off your times. 99 up mustangs (gt and v6) have 3.27 gears
Old 09-13-2005, 07:24 PM   #8
did you mean .25 seconds off the quarter mile??? and how about the gears and a 75 wet shot of nitrous with tune, how much could i get off for that combo.
Old 09-13-2005, 09:08 PM   #9
Monkey's Avatar
from 3.27s to 3.73s you will gain about 0.3 in the 1/4mi.
From the 75 shot of nitrous, you should see about .9 off your ET. (depends on the brand though as some 75 shots are rated at the wheels, some at the crank)
Old 01-03-2006, 04:10 AM   #10
Send a message via Yahoo to dana
373's will give you alot of take off power but when your crusing down the freeway your rpms will be alot higher.
dana is offline   Reply With Quote
Old 01-03-2006, 08:12 AM   #11
if you start with 2.73 gears expect .4-.5 tenths, if you start with 3.27 expect .2-.3~
Old 01-06-2006, 11:04 AM   #12
Herbstang's Avatar
Luv my 3:73 Rpm's at 60 only increased 300
Old 01-06-2006, 09:32 PM   #13
ricklmesa's Avatar
Yea, Im getting 3.73's & a tlok for my Stang I think it has 3.31's stock. Looking forwark to accelerating a bit faster and haver better traction off the line.
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 01-07-2006, 12:14 PM   #14
I took off 5 tenths with the gear change. I already had intake/exaust upgrades though. When I added n20, I put on the 100hp (crank) jets & took off 8 tenths. Then I put on the 150hp jets & took off another 7 tenths. Ill never put on the 150 ones again though.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
3.73's installed ( need speedometer help ) big show 98 Pre-2005 V6 Mustang 8 12-25-2009 06:33 PM
3.73's and T-Lock among other Q's dusty97 Pre-2005 V6 Mustang 7 09-10-2008 02:53 PM
3.73's Sassa Massa 1979-1995 Mustang GT 3 04-13-2007 03:02 PM
Cleaning out the garage: 3.73's/Gauge cluster/trans cooler Suprman Mustang Parts for Sale and Wanted 10 10-08-2004 11:05 PM
12:38 AM
