I got my C springs!!!! - Mustang Evolution
Old 09-13-2005, 03:27 PM   #1
01mineralgrey6's Avatar
now anyone got a pic of the dead coil i should cut off? im looking to install them on sunday.
-Tony
'99 cobra 'vert
Old 09-13-2005, 03:34 PM   #2
I liek gramer
WhiteStang99's Avatar
Re: I got my C springs!!!!
Have fun.
My car has a cut coil in the rear if you're just interested in what it'll look like. Go to my gallery and they're in the most recent folder under My Mustang or somethin like htat.
Old 09-13-2005, 05:43 PM   #3
some C's have em cut anyway so make sure yours does not have it cut already, basically if the top of the rear springs, the very end, gets very flat (very flat) as it ends its uncut, if its blunt then its probably cut a bit)
Old 09-14-2005, 12:50 PM   #4
they are flat,
-Tony
'99 cobra 'vert
Old 09-14-2005, 01:37 PM   #5
Zim
You want to **** me?
Zim's Avatar
If you see the flat part, just go from the end of the coil and cut directly even with it, just the next coil down. Thats cutting 1 coil
Corey gave me a picture when I did mine... Ill try finding it hang on.
I like toys
Old 09-14-2005, 01:38 PM   #6
Zim
Zim's Avatar
here ya go... check this out
cutting C springs ????
I like toys
Old 09-16-2005, 03:41 PM   #7
cool! Thanks!!
-Tony
'99 cobra 'vert
Old 09-16-2005, 05:17 PM   #8
yea a cut off wheel air tool will cut right though that sucker in no time.
Old 09-16-2005, 05:18 PM   #9
i got a friend with a saws all (sp?) would that work ok?
-Tony
'99 cobra 'vert
Old 09-16-2005, 06:31 PM   #10
just about anything will work
Old 09-16-2005, 11:00 PM   #11
I tried it with a grinder...didn't work. Cutting wheel works well, sawzall with metal cutting blade will probably work just as well.
Old 09-17-2005, 07:58 AM   #12
sarahsmustang's Avatar
I am about to install C springs on my daughters 95 V6 Vert.
Should I cut them?
tas
95 Convertible All of the following I installed myself:
JBA wires, reman heads, rotors & pads, radiator, alarm & remote start, convertible top & defrost glass, new cylinder for the convertible top, stereo & speakers, replaced the drivers door, all four O2 sensors, 2000 GT exhaust and a few other sensors here and there. And installed a BBK CAI and a UDP.
And had it painted.
sarahsmustang is offline   Reply With Quote
Old 09-17-2005, 09:25 AM   #13
I liek gramer
Depends on the sort of drop you want. I'm not too familiar with what C Springs do to 94-98s, but my 99 mustang has had the dead coil cut and I wouldn't have it any other way.
http://www.mustangevolution.com/gall...0/IM000893.JPG
Old 09-17-2005, 10:39 AM   #14
if you do not cut a coil from the REAR springs then the rear will sit up a good bit higher than the front. This is ONLY true if the coil has not been cut already.
Old 09-19-2005, 05:37 AM   #15
They are on!cutting the rear coil ended up being harder than i had thought, my buddies saw zaw wouldn't cut it so i had to drive to a guy i work with that has a torch. i got a really nice drop out of it. Id post pics but i have no digi cam...about how much does a decent one run??maybe one i could do videos w/ sound too?
-Tony
'99 cobra 'vert
Old 09-19-2005, 02:23 PM   #16
lol your not supposed to heat those up EVER lol torching them can alter the spring rate. Bring the rear springs they are probably fine but NEVER do that to the fronts
Old 09-19-2005, 05:39 PM   #17
Yeh....heat + springs = no no
Old 09-20-2005, 09:12 AM   #18
You got pics?
PitchBlackstang is offline   Reply With Quote
Old 09-20-2005, 01:25 PM   #19
Zim
Zim's Avatar
Originally Posted by PitchBlackstang
You got pics?
theyd look really good on your car man, i dunno if you ever saw my white v6, but that had the C springs... the drop was great
I like toys
Old 09-20-2005, 09:47 PM   #20
i know but i was desperate, i had no cut wheel, saw wasn't doin anything to it, and it was only a second to cut it
-Tony
'99 cobra 'vert
Old 09-24-2005, 01:34 AM   #21
Thomas91169's Avatar
hey quick question, actually just making sure, but are the flat parts in this pic the dead coil?
i assume i chop 1 full coil off, so the starting point of the coil is the same spot right?
and chopping the dead coil on front and back, the car will still sit a very small amount higher in the back correct(just as if you didnt cut them at all? cause i like the raked look, even if its barely, barely noticeable, and want to get the most out of the springs i can without having to get cc plates.
-Thomas-
Old 09-24-2005, 09:53 AM   #22
I made the mistake of thinking that as well...it took me several tries to get it looking right. Right now I have about 3/4 off in front and back, but I also have about 300 pounds of stereo back there lol
Old 09-24-2005, 10:47 AM   #23
you can see the end of the dead coil on the rears in your picture. Cut the full coil only on the rears, leave the front alone. When you install the fronts leave out the front top isolator. it will lower the front a tiny bit more, and makes NO difference in ride quality. dont cut the front now, you can later but dont now... you cant add coils back.
Old 09-24-2005, 10:54 AM   #24
Especially with your v8..it will lower the front more than my v6 did on the front b/c of the added weight.
Old 09-25-2005, 02:07 AM   #25
well i just installed them without chopping the dead coils. i figure if i do decide to get the roush kit, then i dont want it to be too low and drag the kit, especially when its gonna have side exhaust and 2.5" piping back there under the car.
and it sits pretty even, so chopping the rear prolly mightve given it a *** sag look. ill get pics tomorrow
-Thomas-
Old 09-25-2005, 07:20 PM   #26
i didn't chop the fronts, and i did use the isolaters and got a nice noticable drop... i cut the full coil of the rear and it dropped level for me. ill try to get a pic in the near future. ive gotta get a digi cam
-Tony
'99 cobra 'vert
Springs 1234 1996-2004 Mustang GT 4 04-10-2008 07:01 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 12:13 AM
best springs oaktonarcher Pre-2005 V6 Mustang 10 06-11-2004 06:57 AM
which springs? Danger Dude Pre-2005 V6 Mustang 0 07-15-2003 12:10 PM
03:26 AM
