adjusting the carb on an 82 GL? - Mustang Evolution
Old 09-14-2005, 11:10 AM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
My friend at work has an 82 mustang GL in need of some help to say the least. lol. I took him to my exhaust shop that i always go to to replace one of his catalytic converters. The lady there told us of a smog place we could get a free pre test, so we headed there next......Anyways he passed everything except for the gas part of smog. I wish i had the papers with me, but the limit for gas was suppose to be .99 and he had 9.84! it's running way too rich.
Just wondering if his carb can be adjusted or if he has to get a new one.
I_luv_HP&trq is offline   Reply With Quote
Old 09-15-2005, 02:57 PM   #2
Re: adjusting the carb on an 82 GL?
anyone??
Old 09-24-2005, 06:07 PM   #3
a cheap place to get a carb???
Old 09-24-2005, 06:32 PM   #4
www.ebay.com
Old 09-24-2005, 07:42 PM   #5
^ yea that's the obvious place but i don't like dealing with ebay. i was hoping it could just be adjusted but i guess nobody knows.
Old 09-24-2005, 10:08 PM   #6
I don't know much about carbs...but it seems there should be some sort of adjustment screw in there somewhere...
Old 09-24-2005, 10:51 PM   #7
yea that's what i'm hoping for so he doesn't have to buy a new one. the carb on my camaro is easily adjustable so hopefully i can fix his.
Old 09-25-2005, 12:42 AM   #8
you can adjust almost any carb through the jets that the fuel comes through. it sounds like you jets in the carb is fully open and letting too much fuel in or you may need a new fuel pressure regulator. but you can adjust the jets in the carb assuming it is a 4bl carb. look in a haynes manual to see how exactly or contact your local shop, even a mom and pop shop, they can help you.
bigpomps is offline   Reply With Quote
Old 09-28-2005, 12:14 PM   #9
Ponycarman's Avatar
Unless someone has been dinking with it a simple rebuild and new floats should fix his problem. Don't forget to properly adjust the floats and in general verify/tweak all the adjustments called out in the rebuild kit, as needed of course, if it's in spec don't tweak it. You shouldn't have to fool with the jetting, it's not really adjustable without replacing the jets with different sized ones, so inother words they don;t go oult of adjustment or wear.
Another possibility is that the choke is not opening up, which would make it run rich.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Adjusting the Clutch pringle9666 Pre-2005 V6 Mustang 10 06-14-2010 11:18 AM
Adjusting Idle and Timing sonicpony03 Pre-2005 V6 Mustang 1 07-23-2008 08:14 PM
adjusting the clutch? Murph00 Pre-2005 V6 Mustang 4 01-27-2005 05:02 PM
?adjusting the cam position sensor? Horse Pre-2005 V6 Mustang 24 10-18-2004 06:01 PM
Carb Xvanced 1979-1995 Mustang GT 6 08-25-2004 09:35 PM
05:17 PM
