tranny noise??? - Mustang Evolution
Old 09-15-2005, 02:34 PM   #1
tranny noise???
a nasty clicking noise is coming from my tranny. i have a spec stage 3 clutch and was not smart enough to get a ford t/o bearing and used the spec t/o bearing. is that the problem, or is something else wrong. the clicking is very fast and gets faster with more speed and if i push the clutch in just a little to get rid of the slack the noise stops, and if i push it in all the way it stops too. got any ideas? if it is the t/o bearing how much would it be to fix? btw the noise will still do it if i'm in neutral and the clutch is all the way out.
bigpomps is offline   Reply With Quote
Old 09-16-2005, 02:36 AM   #2
Thomas91169's Avatar
Re: tranny noise???
sounds like TOB to me.
if youre in neutral and its making the noise, does it stop when you apply the slightest clutch pressure? definate TOB problem if so.
now if it was a clicking when the clutch was engaged and no click when it was in neutral, it would be something on the clutch side going(or gone) out.
always use OEM TOB.
-Thomas-
Old 09-16-2005, 12:13 PM   #3
Re: tranny noise???
SpectorV is going to have a field day with this thread
Old 09-16-2005, 02:24 PM   #4
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: tranny noise???
^ for some reason that was funny
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 09-16-2005, 02:25 PM   #5
Re: tranny noise???
is the centerforce to bearing ok to use, or is it just as bad as the spec TOB? i found a TOB sold alone for my stang but its a centerforce TOB and it cost $35, which is reasonable. i just don't know about their reputation for their TOB's. any advice.
Old 09-16-2005, 05:22 PM   #6
Re: tranny noise???
Ive been though 5 throwout bearing so I know a little bit about this lol.....
They have NEVER been able to stop it EVER.
You can delay them going bad by taking up the slack in your clutch petal, if you look in the article section I wrote a how to on adjusting your clutch.
If you are stock... its not gonna work to good, the key is taking all the slack out of the cable, the wobble if you will. So when you touch the petal its firm to the touch, and you have a half inch of pushing in before the car starts to clip in to neutral (go 50mph down the road and hold the gas constant and tap the clutch, go in a half an inch and if it starts to slip after that then you are good)
Keeping the right amount of tension on the cable keeps the throwout bearing healthy. If i let my clutch unadjust its self a bit it will start ticking... I take up the slack and it goes away. This will keep it healthy a bit longer.
Old 09-17-2005, 04:42 PM   #7
Re: tranny noise???
i hear that the way to adjust your clutch pedal is to lift the pedal completely for a short period of time when the car is running to let it align itself. i also just ordered a new centerforce TOB at draxas.com and i hope this one will last a bit longer. i also think i need to change the transmission fluid in it too, its due. i think changing the fluid might help the clutch a little too.
Tranny noise Foxone Pre-2005 V6 Mustang 3 08-27-2008 10:31 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Tapping noise in tranny? 2003TangGT 1996-2004 Mustang GT 1 09-06-2007 01:08 PM
wierd noise InVaDeR Pre-2005 V6 Mustang 16 09-21-2004 05:31 PM
t45 tranny noise? afrankart 1996-2004 Mustang GT 5 06-08-2004 04:33 PM
12:03 PM
