Possibly found metal in my oil pan!!! - Mustang Evolution
Old 09-16-2005, 09:02 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I changed my oil yesterday at work and found a chunk of a snap ring in the drain pan after the oil change. It's possible that it came from somewhere else. Does anyone know of anywhere in the lower end of a 2000 3.8 that there would be a snap ring about 2" in diameter? I looked through the 3.8 service manual and din't find any but I was just hoping for some conformation.
Thanks,
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 09-17-2005, 03:01 PM   #2
97Stallion's Avatar
Re: Possibly found metal in my oil pan!!!
do you have a picture of this snap ring? If I see it, I can maybe remember where it would go in the engine. The only rings I can think of at the moment are the pistons rings, but those are about 4" across and the little rings in the lifters, but those are about 1" across.
Living one day at a time!
Old 09-17-2005, 09:34 PM   #3
Region: Iowa
I know it's not the right shape for either one of those. I dont' have a pic yet, but I'll get one on Monday.
Old 09-19-2005, 01:12 PM   #4
Yeah pics will help tons
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 09-19-2005, 02:11 PM   #5
pictures!
Old 09-23-2005, 12:39 AM   #6
97Stallion's Avatar
any update?
need help removing my oil pan! jkaminski24 1996-2004 Mustang GT 7 08-23-2010 04:54 PM
OIL PAN REMOVAL MR.PEE Pre-2005 V6 Mustang 2 05-01-2008 06:00 PM
Water Possibly Found on Mars Brent The Bar 8 12-07-2006 04:39 PM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 05:14 PM
i found this in the transmission pan tealstangman Pre-2005 V6 Mustang 2 02-22-2004 06:16 PM
11:19 PM
