8.8in swap - Mustang Evolution
Old 09-17-2005, 07:23 PM   #1
Send a message via AIM to charkelly9
8.8in swap
how difficult is this swap from a 7.5 to 8.8... im really looking into it... plus if buy a stock gt rear from a 99+ with the gears be the same as mine so i wont have to get a chip to correct anything??? with the 7.5 driveshaft work with the 8.8rear? thanks
charkelly9 is offline   Reply With Quote
Old 09-18-2005, 04:21 AM   #2
Re: 8.8in swap
Basically what you do is disconnect your 7.5 rear, drop it, put the 8.8 on and you're done. As far as the other little things I have no idea lol. I believe the driveshaft will bolt right up.
Old 09-18-2005, 05:12 AM   #3
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: 8.8in swap
not difficult at all. it's pretty much a direct swap. the stock driveshaft will work with teh 8.8, but while you're there, why not get an aluminum driveshaft to reduce rotational mass in your drivetrain?
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 09-18-2005, 07:53 AM   #4
Re: 8.8in swap
would an 8.8 rear from a 05gt work ?
Old 09-19-2005, 12:53 AM   #5
Kiljosh's Avatar
Re: 8.8in swap
Im going to say no.
The 05 GT is a different chassis than the 94-04 chassis.
Of course, you can take a lesson from our badass four wheeling friends and just make it a custom install. Line the mofo up, measure twice, and weld it to the car.
Old 09-19-2005, 11:28 AM   #6
Send a message via AIM to tedness
Re: 8.8in swap
hmm...
JB Weld ^_^
you're gonna need the quad shocks too.
tedness is offline   Reply With Quote
Old 09-19-2005, 02:19 PM   #7
Re: 8.8in swap
its very easy just takes a bit of time. If you dont need to reuse your axles its even faster. Just jack up the car and support the frame on jack stands, remove the drive shaft bolts, jack up the rear a bit to remove tention, unbolt shocks and then the uppers/lowerss and it falsl out.
Old 09-25-2005, 09:20 PM   #8
Re: 8.8in swap
does this 99 gt rear end look okay? i mean it has 55,000 miles but im considering buying it tomorrow
Name:	gt rear end.jpg
ID:	10750   Click image for larger version
Name:	gt rear end 2.jpg
Old 09-25-2005, 09:22 PM   #9
Re: 8.8in swap
will i have to change my stock struts if i plan to use the shocks with this rear? what about quad shocks will they connect to this rear? thanks guys
Old 09-26-2005, 03:51 PM   #10
Re: 8.8in swap
i won the gt rear end for 153$$ yeah... now im planning to add an aluminum driveshaft and rebuild the rear a bit with new gears and whatever else it needs...
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 09-26-2005, 05:57 PM   #11
Re: 8.8in swap
check for seal leaks and spin the axles and listen to the bearings and what not everywhere.... looks fine from the pics.
Old 09-26-2005, 07:48 PM   #12
Re: 8.8in swap
is it that hard to change the axles? any specific tools i will need or install besides a basics?-dont have an air compressor.
Do we have an article written on how to swap the 8.8 rear in? IF not i will take pics
Old 09-26-2005, 07:59 PM   #13
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
Re: 8.8in swap
wow, thats a good deal...was shipping a ton?
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 09-27-2005, 02:54 PM   #14
Re: 8.8in swap
shipping 65$ this guy is soo cool he made a custom pallet for it to be shipped and said i could us any shipping company in tulsa and he would drive it there
Old 09-27-2005, 05:58 PM   #15
Re: 8.8in swap
okay going on with this swap i wanted to add a gt aluminum driveshaft/ but ive found that they are specific to the type of tranny you have? could a manual driveshaft work with an auto's tranny? why does it matter?
Old 09-27-2005, 06:48 PM   #16
Re: 8.8in swap
yep just put the yoke that fits into your tranny onto the new aluminum driveshaft
Old 09-28-2005, 06:27 AM   #17
dark's Avatar
Re: 8.8in swap
^not true, the auto and manual DS' are different lengths. you need a specific one. check www.crossroadzdirect.com, they should have them
Old 09-28-2005, 04:06 PM   #18
Re: 8.8in swap
well does anyone know about swapping yokes for and auto? and is there a right-up on swapping driveshafts in general or even rear ends?
Old 09-28-2005, 05:19 PM   #19
Re: 8.8in swap
i dont know all i heard was you have to swap the yoke that goes in the tranny, maybe the yokes are different lengths thats why.
Old 09-28-2005, 05:20 PM   #20
Re: 8.8in swap
rear end swapping is just a mater of supporting the rear end with a jack with the body on stands. than unbolting rear swaybar, d-shaft, shocks from botton, lower control arms and upper control arms.
Old 09-29-2005, 03:19 PM   #21
Re: 8.8in swap
damnitt where do i find an aluminum driveshaft that will work with my automatic? i mean all i can find on ebay is 250$ al.drvshafts for manuals.. plus 250 is kinda high
Old 09-29-2005, 03:57 PM   #22
Re: 8.8in swap
the aluminum d -shaft does not make much of a diff.
Old 09-29-2005, 08:41 PM   #23
Re: 8.8in swap
yeah but while im doing this swap i might as well gain a few hp's, lose weight and whatever else.
10:45 PM
