Car problems continue,Speedo' problem - Mustang Evolution
Old 09-21-2005, 11:08 AM   #1
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
alright so i just got home and i noticed id hit 40mph and even if im on the brakes the needle would jump to 45 like there was something wrong with it because it kinda just bounced not go up as if was accelorating.I though maybe i hit a bump while braking and it'd be fine.So i figured only 1 way to find out and tested it a 2nd 3rd and 4th time..same exact thing happened when i hit 40mph wether i was on the brakes or not..anybody have any idea ?
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 09-21-2005, 06:30 PM   #2
Re: Car problems continue,Speedo' problem
Didn't you recently install aftermarket gauges?
Old 09-21-2005, 09:48 PM   #3
Dark02Pony's Avatar
nope stock guages
Old 09-22-2005, 08:18 AM   #4
well the first step would be pulling the clear cover and checking the needle, make sure its not to close to the gauges, if it is it can get stuck and do wonderful things. I doubt this... and if you pull that needle off.... you will have to drive down the road and stick it back on so just pull it out very gently to give it a little room between it and the gauge face.
Now check the VSS sensor located on the tranny. Make sure its in good and what not. After this.... check the line and then you will need to go furhter into the electrical system.
Old 09-22-2005, 12:19 PM   #5
Dark02Pony's Avatar
awesome thanks a lot man ill have to check that out later on :thumbs2:
Vortech supercharger problems car quits running sporter 2005-2010 Mustang GT 15 11-28-2008 05:55 PM
Speedo Problem Justin 1979-1995 Mustang GT 16 02-21-2007 07:37 AM
Continue the story thread.... tedness The Bar 26 08-27-2005 01:57 PM
The Official - Continue My Story Thread! SpectorV The Bar 18 06-13-2005 05:57 PM
Speedo Problem??? v6mustangguy Pre-2005 V6 Mustang 3 02-11-2004 06:47 PM
06:31 AM
