look what i just bought - Mustang Evolution
Old 09-23-2005, 08:01 PM   #1
Send a message via AIM to charkelly9
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
will this work well with my car? cause, i kinda just bought it at a good price.
is there anything else i will need to purchase to install it?... web sites if there is
charkelly9 is offline   Reply With Quote
Old 09-23-2005, 08:29 PM   #2
Kiljosh's Avatar
Re: look what i just bought
I would buy new bolts to install it. Its a good habit to develop, never use old fasteners.
It should bolt right up to your car, same chassis and all. I'm just not sure it will make a difference. It looks like a front sway bar and I'm pretty sure ours come with them.
Wait, just noticed it was a GT sway bar. It may be a bit thicker than your stock one.
Old 09-23-2005, 08:37 PM   #3
do the end-links help at all? does the stock '03 have endlinks? or should i resell this item cause it wont even have an effect over the stock?
Old 09-23-2005, 09:11 PM   #4
get a gt rear bar to compliment the front one, your stock endlinks should work fine.
Old 09-23-2005, 09:43 PM   #5
To be honest...a front gt swaybar will not do you much good. ...
Old 09-24-2005, 05:53 PM   #6
Ponycarman's Avatar
Depending on your setup the bar may or may not have much of an effect.
Generally speaking a stiffer front bar will tend to decrease oversteer (loose rear).
My 96 has the stock bars front and rear and the rear is loose, this is due to changes I made in other suspension components. I am debating removing the rear bar or stepping up to a thcker bar in the front. I'll probably pull the rear bar to see if it helps then I'll contemplate a bigger fornt bar and reinstall the rear bar.
Your suspension is all interrelated and changing one part will affect the whole.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 09-24-2005, 06:33 PM   #7
the front sway bar will be identical to yours, if not smaller. Keep what you have.
just bought me a.... Warfire80 The Bar 4 05-22-2004 12:05 PM
Just bought 98VroomVroom Mustang Audio & Video 14 01-05-2004 11:01 AM
just bought... JoeR. Mustang Audio & Video 9 12-09-2003 02:58 PM
Just bought Another V8 v6stanger The Bar 18 09-18-2003 10:31 AM
05:46 AM
