would this work? - Mustang Evolution
Old 09-23-2005, 08:34 PM   #1
Send a message via AIM to charkelly9
would this work?
a local guy sent me this message about a turbo hes selling b/c he wants my in the dash dvd player.. would this work on a mustang?/ or would it spool to early? roughly how much would it cost to install this?
Master power t61, bran new
61 trim Compressor wheel: (flow more than 65 lbs/min)
-Inducer = 2.381" (60.5mm)
-Exducer = 3.307"
0.70 A/R compressor housing.
P-trim Turbine Wheel: (64.5mm)
-Inducer = 2.539"
-Exducer = 2.913"
T4 Tangential Turbine Housing (P-trim), .68 A/R
V band flange is machined into turbin housing.
$600
Obx intercooler, very popular with the turbo fbody's, bran new
24x12x3 with 3 inch inlet and outlet, bar and plate intercooler
$300
Tial 40mm wastegate, bran new
Silver top
1 bar spring
comes with one of the 15 dollar dump tube flange and hardware
$360
Turbox's RFL bov and pipe for a mk3 supra, routes though the snorkle hole in good condition, just needs a new home.
$150
what other parts would i need?
charkelly9 is offline   Reply With Quote
Old 09-23-2005, 09:43 PM   #2
Re: would this work?
Alot of piping and some engine work to handle anything over about 6 psi.
Old 09-25-2005, 10:20 AM   #3
Tbird232ci's Avatar
what engine are we talking about?
having the parts is one thing, but youre going to need to have a lot of cutting, welding, and customizing done to get those parts on the car
Old 09-25-2005, 12:07 PM   #4
yeah this might be outta my league.. i dont wanna spend thousands to put this on... thus im just gonna go with a vortech kit designed for a 2003 v6 lmk if you find on
Old 09-25-2005, 12:11 PM   #5
in the end buying a kit that will bolt on will most definatly be cheaper unless you can fab it yourself. i wouldnt turbo a car unless the motor was build and ready to handle it.
Old 09-25-2005, 12:18 PM   #6
how many psi will a vortech kit most likely run on my stock engine? and if i rebuild it forged then how many psi... is it true that 1 psi means 15 hp?
Old 09-25-2005, 02:01 PM   #7
Tbird232ci's Avatar
Your car being a V6, and probably relatively stock, that turbo would be too big for your car
the 1psi=15hp is just one of those stupid generalizations, it depends far too much on the setup, the specific blower/turbo, intercooled or not, and everything else
a high compression engine, 1psi could be 15hp, while on a low compression engine, it could only be 6hp, there is no set number
Old 09-25-2005, 02:35 PM   #8
DarkShadow's Avatar
Send a message via AIM to DarkShadow
TMAturbo kits are good for 19hp per pound on stock v6's. Stock, a ford 3.8 can handle no more than 11psi. 10 is the highest I would go. You'll probably end up spending more to get it to work than just buying a bolt-on. Especially if it's used, don't buy it.
DarkShadow is offline   Reply With Quote
Old 09-25-2005, 04:34 PM   #9
Tbird232ci's Avatar
19per PSI is because you V6 boys have high compression
i have 8.0:1 compression, run 18psi, and make around 200 at the wheels
Getting some work done Scut95 The Bar 5 06-15-2009 09:11 PM
Some of my Work. Dwisforme05 Pictures and Videos 16 02-10-2009 09:39 AM
So where does everyone work? Dom The Bar 52 11-30-2006 05:50 AM
I work to much rocknbronco The Bar 4 09-12-2006 11:47 AM
would this work? Fishers Stang The Bar 9 10-26-2004 06:25 PM
04:31 AM
