suspension installation - Mustang Evolution
Old 09-25-2005, 10:05 PM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
ok on the how to article on this site it suggest using the differential and K member as a jacking point. but in my owners manual it says in i think 2 different locations to never jack the car up under the diff or k member. will the stress on these parts cause any problems? or is it just written like that in the manual so nobody attempts to try it?
i'm not saying his how to article is wrong by any means, just want to know the best way to install my suspension package in the future.
I_luv_HP&trq is offline   Reply With Quote
Old 09-25-2005, 10:08 PM   #2
Re: suspension installation
I always jack my car up on the front K member and the rear up on the pumpkin of the differential.
Old 09-25-2005, 10:12 PM   #3
yea i've done it before too until i read in the manual to not do it ever. I'm just extremely paranoid about everything now and don't want to put stress on the wrong part of the car.
Old 09-25-2005, 10:22 PM   #4
I jack my car up on the K member all the time....lol. Never read that before.
Old 09-25-2005, 10:37 PM   #5
I would not worry about it...
Old 09-25-2005, 10:48 PM   #6
01mineralgrey6's Avatar
i do the same aswell
-Tony
'99 cobra 'vert
Old 09-25-2005, 10:48 PM   #7
ok but if something goes wrong you guys owe me a new car. lol
i'll take an 03 cobra in that dark dark blue.
Old 09-25-2005, 11:21 PM   #8
good choice
-Tony
'99 cobra 'vert
Old 09-25-2005, 11:22 PM   #9
Yea 01mineralgrey6 with be sure to get it for you
Old 09-25-2005, 11:23 PM   #10
:pnoid:
-Tony
'99 cobra 'vert
Old 09-25-2005, 11:26 PM   #11
i have heard that when you jack from the pumkin it makes it go like this ( because the support is on the middle and you allow the sides to sag
but i dont know if it is true
Old 09-25-2005, 11:33 PM   #12
Where do you suggest jacking it up from
Old 09-26-2005, 05:15 AM   #13
Danger Dude's Avatar
It would be better to jack the front at the jack body point and then if you need to raise or lower the front spindle or A arm you use a second jack. Jacking from the pumkin is fine but I would stress not keeping it there for your safety and put Jack stands on the axle housings.
Old 09-26-2005, 03:36 PM   #14
i always jack from the pumpkin, like i said i dont know if its true its just something i have heard, but i have never had a problrm. of course its only there while i position jack stands
Old 09-26-2005, 05:30 PM   #15
Yeh..good point, I only lift my car at those points while I place jack stands, I never leave the car up on the jack, don't trust it near that much.
Old 09-26-2005, 05:54 PM   #16
If you need to raise the front end to place the car on jack stands its nearly impossible to do so with out jacking from under the K member. You cant evenly raise both sides of the car at the same time from another point. You could jack each side by the frame rail jack points, but you try putting a jack stand under one side at a time.....
Just take it easy on it and you wont have a problem jacking the car from the K member.
As far as the rear of tthe car, you can jake by the pumpkin if you make sure to put no stress on the rear end cover. Make sure no jack teeth are pushing on it or what not and you should be fine.
exhaust installation help blue-saleen Pre-2005 V6 Mustang 2 11-09-2009 07:21 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
New Headlight installation corkwood06 Pre-2005 V6 Mustang 3 11-29-2007 06:57 AM
just finished installation whipster24 Pictures and Videos 3 12-04-2004 07:10 AM
Installation Frustrations... BuddyLee Mustang Audio & Video 19 11-09-2004 03:43 AM
02:52 AM
