New Plug Wires - Mustang Evolution
Old 11-06-2009, 05:22 PM   #1
Foxone's Avatar
New Plug Wires
So I ordered a set of new wires, I noticed the old ones are routed around the back of the engine, any issues with running across the front of the intake manifold instead? Probably use some nice seperaters and make it clean, I would think they would stay cooler up there also.
Foxone is offline   Reply With Quote
Old 11-06-2009, 06:19 PM   #2
MonteCitan's Avatar
Re: New Plug Wires
You can technically run them wherever you'd like - heat doesn't affect them much.. They're routed that way for a reason.. If you do change it around, just be sure you don't mix up which goes where and be wary of any contact points where the wire could rub through..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
spark plug wires... which one? electricstang Pre-2005 V6 Mustang 6 09-15-2005 02:19 PM
Plug wires ....change them? Ghostbuster Pre-2005 V6 Mustang 4 04-23-2005 07:18 AM
Plug wires Ghostbuster Pre-2005 V6 Mustang 0 04-10-2005 06:57 AM
Spark Plug Wires Laser02 Pre-2005 V6 Mustang 32 11-08-2004 08:30 AM
Spark Plug Wires Shahrum Pre-2005 V6 Mustang 10 02-05-2004 10:09 AM
10:18 AM
