run 16.3 in high heat/humid...low temp good for 15's? - Mustang Evolution
Old 09-28-2005, 11:10 AM   #1
Send a message via AIM to tedness
basically i ran consistently from 16.4-16.7 at the track this summer. my fan didn't kick in but once in a while and the outside temp was around 90* w/ something like 80% humidity.
back then i had 45psi in the tires, short shifter, CAI, cheapo exhausto.
dropping my tire pressure, addition of gears/t-lok, and about 70* temps outside, can i realistically get my car into the 15's? (disregarding driver ability)
tedness is offline   Reply With Quote
Old 09-28-2005, 11:11 AM   #2
Re: run 16.3 in high heat/humid...low temp good for 15's?
yes.
Old 09-28-2005, 11:26 AM   #3
sweeet. out of the 16-second block and in there w/ GS-R's
Old 12-04-2005, 04:21 PM   #4
Send a message via Yahoo to 95gt350
nice i all so ran 15's to do u have a cat back exshaust
95gt350 is offline   Reply With Quote
Old 12-05-2005, 10:08 AM   #5
what are your 60fts like? your car is capable of doing mid 15s stock at the right temp and alt (with good weather of course)
Old 12-05-2005, 03:47 PM   #6
Monkey's Avatar
going from 3.27 to 3.73 is good for about 0.3 in the 1/4 alone. Just be careful that you don't lower your tire pressure too low. You will increase rolling resistance and will slow your car down.
If anything, drop them to about 35psi in the rear and try to bump them up in the front to 45-50psi. That will decrease the rolling resistance in the fronts and allow you to hook up in the rear. If you still spin off the line due to the gears, drop the rear tire pressure no less than 25psi.
Good luck to ya :thumbs2:
Old 12-08-2005, 01:55 PM   #7
I took off .5 tenths when I put my gears on.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 01-02-2006, 12:56 PM   #8
when i get some gears in i'm looking at cutting some low 15's because i know i can get my 2.4 60' down.
SCT Power tuner just added, oil temp seems high? Camaro Eater Pre-2005 V6 Mustang 6 06-12-2010 08:17 PM
I think my good luck has run out. fast64 Pictures and Videos 16 02-08-2007 02:15 PM
finished high school, got wasted, life is good! tedness The Bar 15 05-30-2005 11:14 PM
09:50 AM
