Service Engine Soon light on - Mustang Evolution
Old 09-28-2005, 06:20 PM   #1
I liek gramer
WhiteStang99's Avatar
My Service Engine Soon light recently came on and has stayed on the past 2 days. I have noticed no problems with the car whatsoever. It accelerates and handles loads as well as it always has.
My car recently rolled over 97,000 miles, the light came on around 97,300. Is this just a "please take your car to Ford for 100k mile maintenance" or possibly something more serious?
Old 09-28-2005, 06:56 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Service Engine Soon light on
your car is saying "hahaha, I'm gonna own you".... you can check the tripped code. push your trip od. button, hold it in, and start your car, still holding it in.... I forget what year they did this, maybe your's doesn't have it... I know mine does... it's a 2001. Anyway, you can check tripped codes with that menu.
Old 09-28-2005, 07:28 PM   #3
slvr2000stang's Avatar
No that will not read the code.
You need to do an OBD2 scan.
It can be anything except mileage tripped.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 09-28-2005, 07:43 PM   #4
Region: Iowa
you sure? There are crap loads of codes that pop up.......
Old 09-28-2005, 08:16 PM   #5
Region: Iowa
Here are the DTC trouble codes (thanks Steve 99 Cobra):
9202 Fuel sender open circuit
9204 Fuel sender short to ground
9213 Anti-theft number of programmed keys is below minimum
A103 or 9232 Antenna not connected-defective transceiver
9317 Battery Voltage high
9318 Battery voltage low
9342 ECU is defective
9356 Ignition run circuit open
9364 Ignition Start circuit open
9600 PATS Ignition Key Transponder Signal is Not Received - Damaged Key or non-PATSKey
9601 PATSReceived Incorrect Key-Code from Ignition Key Transponder (unprogrammed Encoded Ignition Key)
9602 PATS Received Invalid Format of Key - Code From Ignition Key Transponder (Partial Key Code)
9681 PATSTranceiver Signal is Not Received (Not Connected, Damaged, or Wiring)
A139 PCM ID does not match between Instrument Cluster and PCM
A141 NVM Configuration Failure (No PCM ID exchange between Instrument Cluster and PCM)
A143 NVM memory failure
5284 Oil Pressure Switch Failure
D027 SCP Invalid or Missing Data for Engine RPM
D041 SCP Invalid or missing data for Vehicle Speed
D043 SCP Invalid or missing data for Traction Control
D073 SCP Invalid or missing data for engine coolant
D123 SCP Invalid or missing data for Odometer
D147 SCP Invalid or missing data for vehicle security
D262 Missing SCP message.
Old 09-28-2005, 08:35 PM   #6
Joel5.0's Avatar
Try this to verify if the SES is on due to something as simple as not tightening the gas cap completely (yes, it will turn on the SES even when the problem or fault is corrected and will stay lit if no reset to the computer is done).
Disconnect battery for 2-5 minutes to reset system, reconnect battery and verify SES stays off after starting engine. If it becomes lit again....it definetely needs service and yes, you need an OBD-II scanner.
Joel5.0 is offline   Reply With Quote
Old 09-28-2005, 08:54 PM   #7
I liek gramer
I had filled up a day or two before the code came on (yeah, i thought about that) and haven't filled up since, so I'm pretty sure it's not the gas cap.
I didn't know if Ford programmed them to trip at a certain mileage, just seemed like a thought.
I guess I'll take it to an Advanced and see what they have to say.
Yeah, Jimmy, that trick works for 99-04, but it won't read codes.
Old 09-28-2005, 08:56 PM   #8
Hm...just go to advanced auto and get it checked or something, autozone or whatever
Old 09-28-2005, 08:57 PM   #9
I liek gramer
:chin:
Old 09-28-2005, 09:05 PM   #10
Hahahaha, shutup, I was preoccupied when I posted that.
Old 09-28-2005, 09:15 PM   #11
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Take it to Advance or something.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 09-29-2005, 06:58 AM   #12
It doesn't trip at a certain mileage. You need OBD2 codes read. The cluster codes are for just the cluster.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 10-01-2005, 02:00 PM   #13
I liek gramer
EGR Flow Insufficient
EGR Flow Excessive
So tell me everything there is to know about the EGR Valve. All I know is that it puts exhaust gases back into the combustion chamber to lower temps and reduce NOx byproducts, thanks to Chiltons.
I know it's possible to delete this, but I'd rather not. How much would this be to fix, can I do it, etc.?
Old 10-01-2005, 03:25 PM   #14
Region: Iowa
why not see what Advance has to say? (to quote someone else.. maybe they'll know something)
Old 10-01-2005, 05:16 PM   #15
Joel5.0's Avatar
The pinpoint test procedure for the codes mentioned is of 35 - 45 steps that also require the use of a scanner. There are vacuum hoses/lines, exhaust pressure hoses (2), conectors, one pressure sensor, one vacuum solenoid, wiring, the EGR valve and the computer to check.
Since the codes are the opposite of one another, again....do a reset of the computer and verify if they are real codes first, you'll save time and money. Otherwise.....
Old 10-02-2005, 07:03 AM   #16
I would replace the DPFE, they go bad a lot on 99-00, get one at ford or the autoparts store.
Justin Starkey
Old 10-02-2005, 04:28 PM   #17
I second the DPFE replacement.
2000 Vert 4R70W
Old 10-02-2005, 04:34 PM   #18
I have a complete EGR system sitting here from my 02 if all you wanna do is replace it lol.
Old 10-02-2005, 07:33 PM   #19
I liek gramer
holy crap guys, do you think I just asked my car what the problem was? I took it to Advanced and the codes read for EGR FLOW INSUFFICIENT and EGR FLOW EXCESSIVE....
Old 07-22-2015, 08:41 PM   #20
Have advance clear code and see if comes back on..most likely won't
ALLYDRIVER1 is offline   Reply With Quote
Old 07-22-2015, 08:42 PM   #21
Oops just saw date posted,oh well still good advice for someone doing a search
Service Engine Soon light >< Hoss001 Pre-2005 V6 Mustang 10 07-23-2015 06:21 AM
Service engine light :( explicitrock General Mustang Discussion 0 07-15-2010 10:02 PM
service engine light OXstang11 Pre-2005 V6 Mustang 14 10-28-2005 04:29 PM
Service Engine Light Mustang Val Pre-2005 V6 Mustang 12 12-27-2003 06:52 AM
service engine soon light tek55 Pre-2005 V6 Mustang 4 11-13-2003 02:00 PM
01:55 AM
