Uh Oh - Mustang Evolution
Old 08-22-2003, 02:17 PM   #1
Ken
Ken's Avatar
Region: New Hampshire
Uh Oh
So Guess what was waiting for me when I got home???
Ken is offline   Reply With Quote
Old 08-22-2003, 02:20 PM   #2
Ken
Ken's Avatar
It's kinda reddish brown.
Transmission fluid level is good
Oil level is good
brake fluid could probably be added..
Any ideas?? Since my tranny fluid level looks ok, I'm at a loss right now..
Can't afford Mods? Go To College!
Old 08-22-2003, 03:14 PM   #3
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
Your trans fluid will stay looking good until you start it up. Thats why they say to check the fluid while the car is running. The fluid is pumped when the engine is turned on. I'll bet that it's trans fluid... and a lot of it. Can you tell where it came from? where was it dripping from?
And BTW... THATS A LOT OF FLUID!!!
Rellik is offline   Reply With Quote
Old 08-22-2003, 05:25 PM   #4
Ken
Ken's Avatar
So how do you top off the tranny fluid?? Pour it down the tube where the dipstick is??
I'm moderately conviced it's the gasket. I first noticed the leak after the snow left and it looks like it's dripping from the seal where the plate is that has all the screws on the bottom of the tranny. I'm guessing the plate is where the filter is.. So should I go to ford, get a new filter and drop the plate, replace the filter and gasket and put it back together?
Again, HTF do you fill the tranny fluid?
Old 08-22-2003, 05:28 PM   #5
Yup
Its a lenghtly process actually.
But if you want to, you CAN change your own trans pan gasket, and while you're doing that, I would suggest changing the trans fluid filter at the same time (which is located in the trans pan if I'm not mistaken).
I've changed trans gaskets before... It's EXTREMELY MESSY!!!! Wear goggles!! 8)
Old 08-22-2003, 05:30 PM   #6
Ken
Ken's Avatar
So worth it to pay a shop $100 or so to take care of it for me?
Old 08-22-2003, 05:35 PM   #7
Depends... a shop could change it for you in about 4 hours... or you could do it by yourself in about 8 and a lot of headaches and tasty trans fluid... Trust me... it doesnt taste good either
I would take it in personally. I dont have the time anymore to do it myself with my schedule. I wish I did
Old 08-22-2003, 05:41 PM   #8
Rick0636's Avatar
In his case it might not be so bad, looks like most of it has already leaked out anyhow, whew! Get a pan to catch it, get it on ramps or jackstands. Loosen all of your pan gaskets first, then work one side down more than the others, take all of them out of two opposit ends, then loosen one side pretty good, then take them all the way down on the other, it will drop and all the fluid will come out in a hurry, if not you may have to pry a little with a screw driver, but not usually. Try to stay out of the way if you can! This is the perfect time to do a good mod on your car if you can get the part. either get a drain plug for your current pan or get a pan with a drain plug already in it. It makes it 10X more easy to change your transmission fluid and the filter seldom really gets dirty. However since you had to drop the pan, replace the filter this time.
Old 08-22-2003, 05:48 PM   #9
Ken
Ken's Avatar
That's what I had in mind Rick.. But if Evin suggests it's an 8hr process......
Should I just take it to a tranny shop and have a shift kit installed?
Shift kit
filter
gasket
pan/plate with drain plug
Old 08-22-2003, 06:53 PM   #10
Maybe 8 hours is a little extreme, I'll admit that I went a little overboard. There is about 20 or so bolts from what I remember.
It's not just an easy on and off. But if you have a shift kit.. you may want to take it in anyway
Old 08-22-2003, 07:19 PM   #11
Rick0636's Avatar
Yeah, good time to get a shift kit put in, no need to waste all that transmission fluid twice!!
Old 08-22-2003, 07:25 PM   #12
Rick0636's Avatar
Might be a good idea to get it in to a transmission shop and make sure that just changing the pan gasket is going to cure your leak too. another favorite spot to leak out is around the driveshaft out what is known as the rear main seal.
Old 08-22-2003, 07:27 PM   #13
Rick0636's Avatar
But I did a lot of fluid and filter changes in transmission class in Automatic Transmission Class at school, I would do sometime 2 of them in one class and have time to spare in just one afternoon. So no, its no 8 hour thing. But this was ideal conditions with a lift and the right tools and equipment too.
Old 08-22-2003, 11:05 PM   #14
Ken
Ken's Avatar
Old 08-23-2003, 10:03 AM   #15
Rick0636's Avatar
Old 08-23-2003, 10:04 AM   #16
Rick0636's Avatar
Old 08-23-2003, 05:03 PM   #17
Ken
Ken's Avatar
Old 08-23-2003, 05:04 PM   #18
Ken
Ken's Avatar
Old 08-23-2003, 07:35 PM   #19
Rick0636's Avatar
Old 08-23-2003, 08:54 PM   #20
Monkey's Avatar
Old 08-27-2003, 08:00 AM   #21
Ken
Ken's Avatar
Old 09-03-2003, 05:45 AM   #22
Ken
Ken's Avatar
So $220 later I have no more leaks!
Turns out it wasn't the gasket.
Took the tranny shop about 5 minutes to figure out the trouble.
When I took my car to that POS 5.0 performance shop in Nashua, NH to have the headers and exhaust installed, they unbolted the tranny dipstik tube and BENT IT out of the way. that caused the seal between the tube and the tranny to have a gap not allowing that rubber grommet gasket thing to properly seal and the leak was coming from there.
I first noticed the leak right after the shop installed my exhaust. So I called and talked to them about it and they were way defensive, insisting that they did not do anything remotely near the tranny that would cause a leak..
This was back in November, so although I have the bent part, I have no recourse with them to reimburse me for the repairs.
Bastard 5.0 Performance in Nashua SUCKS MY LEFT NUT!
Old 09-03-2003, 06:01 AM   #23
yea pro 5.0 def. sucks. sorry to hear.
Old 09-03-2003, 06:05 AM   #24
Ken
Ken's Avatar
On the other hand, Freddy's Transmission in Hudson NH gets a thumbs up. They are a very respected shop, but not a performance shop. They really didn't want to get involved with installing a shift kit or performance Torque Converter on the 4R70W tranny because 'it's not really designed for that'. They repair trannys to factory specs, using factory parts and recommended fluid. So I couldn't get to first base with them on using Royal Purple, or swapping the tranny pan for one with a drain plug..
Old 09-03-2003, 07:28 AM   #25
I can understand small shops not wanting to install performance products for the reason that if the product fails or not performs correctly, it could be "blamed" on the person who installs it. But they could've installed royal purple lub in it. thats nothing..heh. Guess you have a weekend project to do sometime.
02:29 PM
