Tires for drag racing 05' - Mustang Evolution
Old 09-29-2005, 02:46 PM   #1
Question Tires for drag racing 05'
I've got an 05' gt. I haven't raced on my local drag strip yet, but I'm itching to get out there. What rims and tires would you suggest? Just enough to get the job done correctly.
jones4stangs is offline   Reply With Quote
Old 09-29-2005, 05:27 PM   #2
Re: Tires for drag racing 05'
You can run on just your stockers. If you get real serious into it, buy some good drag radials later on down the road. Just normal steel belted radials will get ya fine man.
Old 09-30-2005, 03:16 PM   #3
The new MT ET drag radial from what I have read is a nice option .Don't forget you will need a drive shaft safety loop.
GT-Eater is offline   Reply With Quote
Old 09-30-2005, 03:22 PM   #4
You shouldn't need one for a while...not until you hit the tracks magic number which differs from track to track. With a stock 05 GT, you should be plenty fine without the loop.
Tires, the stockers will get you by just fine for the time being. If you do get serious, I would look at the MT's like GT-Eater said, but I wouldn't use those as your street tires. They tend to wear on the street real fast. Grip great at the track though. I have heard that they are only getting about 3-5k miles on the street. If you want streetable DR's, get the Nitto 555R's. They will last about 15k or so miles depending on your driving habbits. You will sacrifice some traction at the track though, but nothing super bad.
Old 10-01-2005, 03:16 PM   #5
Thanks for the info.
I'd never heard of a drive shaft safety loop before. Did a quick search. Thanks for the heads up, definetly sounds like something I need to get.
As far as racing on the stock tires vs drag, what kind of cost are we talking?
Does one type generally run more than the other?
I think I've got:
Pirelli P-Zero Nero M+S P235/55ZR-17 98W B (41894) $139.00each
Ideally, I figured I'd have a different set of rims and tires for street use and drag use. I use my car everyday.
Old 10-01-2005, 05:20 PM   #6
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
:yup: just use your stock wheels and put the radials on for the track
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 10-11-2005, 07:44 AM   #7
MonteCitan's Avatar
I put nitto 555Rs on my '02 GT, even around town it made a huuuuge difference in driving - car would hook between shifts and everything.. was a hella lot more enjoyable than street tires... Never got to use them at the track but shoulda been good for a .2 or so drop in my 60'...
They were also BETTER in the rain than my street tires were
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-19-2005, 11:08 AM   #8
THUNDERJET T/C's Avatar
Send a message via AIM to THUNDERJET T/C
the m/t's also work better then any drag radial on the market.
ive ran 1.60 60 fts on them
THUNDERJET T/C is offline   Reply With Quote
Old 01-03-2006, 09:50 AM   #9
I posted this in the whieels/tire section but got no responses
I'm looking to get some drag tires for my 05' GT.
Mickey Thompson ET Street Radial
http://www.mickeythompsontires.com/s...et_radial.html
Is there a size that would fit my GT stock rims (17x8)? The P275/40R17?
Any suggestions on different rear rims to match with these tires?
Is is reasonable to change tires off a rim, or a better idea to just buy new/used rims for the drag tires?
05' Mustang GT, C&L Trueflow air intake, DiabloSport Predator tune
Old 01-03-2006, 02:33 PM   #10
slvr2000stang's Avatar
Seperate rims for the DR's is the easiest way to go.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-07-2006, 11:58 AM   #11
Nitto drag radials are the best. I have had both bfg's & nittos. The nittos last alot longer but I think the bfg's hook better. Just dont do too long of a burnout. I killed half my tires one day at the track.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Drag racing Js281GT ME Site Help & Announcements 6 04-17-2006 06:28 AM
Cams and drag racing... Exit_In_Red Pre-2005 V6 Mustang 7 02-07-2005 03:51 PM
drag racing with an auto greenpony02 Pre-2005 V6 Mustang 19 11-15-2004 05:43 PM
no drag racing oaktonarcher The Bar 18 10-03-2004 09:19 AM
Alittle ricer drag racing/street racing show on History channel video Brent The Bar 15 05-06-2004 11:26 PM
11:47 PM
