t5 swap - Mustang Evolution
Old 10-02-2005, 07:04 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Question t5 swap
wattup all.. ok well i was wondering how extensive and exPENsive it would be to swap out an auto to a stick... see i have somone who is willing to sell me his t5 transmission for 200 bucks. its in pretty good shape (atleast the outside of it).. i was wondering what i would need and if this would be advisable to buy.. thanks guys THIS SITE is the SH**
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 10-02-2005, 08:05 AM   #2
97Stallion's Avatar
Re: t5 swap
Figure you'll need the tranny and a tune, the pedal assembly and a clutch assembly(clutch, flywheel, cable). You might even need a new bellhousing that has the pivot for the throwout bearing. So maybe $1500
Living one day at a time!
Old 10-02-2005, 04:23 PM   #3
Re: t5 swap
Brent is doing the same thing to his...ask him about it.
Old 10-03-2005, 05:52 PM   #4
Re: t5 swap
brent? what would i have to update? or is it mainly a direct swap? aside from the clutch, flywheel and pedal assembly, what else would i need? how about the ecU? would i have to update to like a manual ecu?? or can i use the same one sorry guys newbie..
"Shake n bake"
Old 10-03-2005, 06:33 PM   #5
Re: t5 swap
Ok made up my mind... going to swap for a manual and need input
Old 10-04-2005, 07:51 PM   #6
Re: t5 swap
thanks brent! hows it running>? update me on ur condition.. thanks again
"Shake n bake"
Old 10-13-2005, 09:14 AM   #7
Re: t5 swap
i priced a brand new t-5 a whild back at like 800 bucks from www.gefracing.com but... im sure they have went up. I personally would not buy a used tranny with out a GOOD bit of info on what kind of condition it is in. Which i doubt you can get... you dont want to have issues with it.
I would spend the extra and do it right. You could probably get it done for 2 grand~ if you did the work yourself~ maybe 2.5
I would just sell the car and buy another one since 2.5 grand is probably over half what the car is worth. Swaping in a manual will kill the resale value and you couldnt sell it for more than you would before, less probably.
Old 10-19-2005, 09:18 PM   #8
Region: Iowa
Re: t5 swap
I know mine is a 4-cyl Fox body, but I did mine for less than $600.
$200 T-5 and bellhousing
$200 Stock replacement clutch (came with throwout bearing)
$050 For all the small parts from a JY (cable, pedal assy, etc)
$030 Flywheel resurfacing
While the pedal assembly is out I would go ahead and put in a St33da clutch quadrant and firewall adjuster, It is a PITA to change while the pedals are in the car. i finally got frustrated and just took my pedal assy out.
http://projecthp.ford23.com/howto.html
This is the link to where I got my info on how to do this. The first time I did this it took me a week. the second time was in only about 6 hours.
When I did it to my first NA 2.3 I used the auto ECU and the only problem was that it spat out a code that the torque converter was not locking out.
I do not know if the EEC-V would react differently though.
1990 Mustang LX 2.3Turbo
Turbo Swap, 5-Speed Swap,Adjustable Boost valve(set at 15psi), Walbro 255lph(high pressure) fuel pump, 35# Injectors, Garrett T-3 Turbocharger(.60/.63)
4sd4d is offline   Reply With Quote
4.6 swap to a 5.4 b's stang 2005-2010 Mustang GT 9 06-21-2010 10:26 PM
Possible V8 Swap? NeedSomeMods Pre-2005 V6 Mustang 5 05-18-2010 03:43 PM
4.6 - 5.4 swap bruyn 1996-2004 Mustang GT 19 01-21-2010 07:25 AM
5.8 swap ? Z-EATER 1979-1995 Mustang GT 1 05-19-2008 06:29 AM
To Swap, or not to swap...... Strongarm 1979-1995 Mustang GT 5 02-05-2008 02:39 PM
04:32 AM
