rear suspension need help fixing it... - Mustang Evolution
Old 10-02-2005, 11:15 PM   #1
rpm
ok so i installed all my shocks, struts, and cc plates and the rear end turned out like this...
anyone have and ideas as to what i should do? should i just let it settle and see what happens or should i take it to a shop?
rpm is offline   Reply With Quote
Old 10-02-2005, 11:18 PM   #2
I liek gramer
WhiteStang99's Avatar
Re: rear suspension need help fixing it...
spring isolators on the side that is lower might help. other than that, i dunno.
Old 10-02-2005, 11:20 PM   #3
Is it lopsided? Did you take an isolator out the left side and left one in on the right side? There's a ton of things that could happened.
When you put in your rear struts, did you make sure they were seated properly and torque them down correctly?
Did you replace springs? and if so, did you check them to begin with to ensure they were the same height, the same spring, the same rate?
There's a ton of things that coulda happened to do that...does it seem is is worst in the front or back?
Old 10-02-2005, 11:24 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
just put a fat lady in the passenger seat.
I_luv_HP&trq is offline   Reply With Quote
Old 10-02-2005, 11:37 PM   #5
rpm
i took out the isolator on all four sides and now its all fvcked over... and yes it is crooked...
Old 10-02-2005, 11:43 PM   #6
1) Did you change the springs? If so...did you check and see the springs are the same.
2)Did you ensure the shocks/struts were seated properly?
3)Did you ensure the springs were seated properly?
4)When you installed the c/c plates, did you ensure the spacers were properly installed?
5)Did you torque everything on the suspension back properly?
6)Did you ensure there was nothing in the way of the suspension going back to it's proper location?
There are a ton of things to check on this. It looks to me, with no given information, that the springs are different heights.
Old 10-02-2005, 11:54 PM   #7
rpm
all those question are a yes... besides the one where u were talking about different sized springs i tooked them out and one was slightly taller then the other but i dont think it will give me that much of a difference in how it sits... but i could b wrong
Old 10-03-2005, 12:07 AM   #8
There is a difference in height between the front and rear springs. But both front springs should have been the same exact size, and both rear springs should have been exactly the same size. Were they?
Old 10-03-2005, 12:44 AM   #9
rpm
theres no problem with the front its jus the back is crooked like that... and the rear springs one was jus a lil taller then the other...
Old 10-03-2005, 01:08 AM   #10
01mineralgrey6's Avatar
correct me if im wrong, but i belive that the "pigtail" of the bottom of the spring is supposed to point torwards the drivers side of the car. im not 100% on that though. might be worth looking at.
-Tony
'99 cobra 'vert
Old 10-03-2005, 01:20 AM   #11
rpm
ur right...
Old 10-03-2005, 07:52 AM   #12
If one rear spring is just a little taller than the other....that will cause a difference in side to side height. But that shouldn't make that big of a difference unless they are like an inch difference.
Now...if a pigtail is turned different and the springs are slightly different heights, that would cause that.
Old 10-03-2005, 08:59 AM   #13
rpm
the pigtails point exactly the same way...
Old 10-03-2005, 10:18 AM   #14
does it right normal? if you just put shocks in one of the shocks may not be working exactly right, keeping it up in the air. driveover something to compress the side thats highter a couple times and drive it a few miles to see if it gets better.
Old 10-03-2005, 11:17 AM   #15
Did you compress the rear shocks a few times before putting them on? I've heard it's best to compress them by hand several times to get them working correctly again since they normally sit up in storage buildings for months.
Old 10-03-2005, 11:28 AM   #16
rpm
do u mean push them together by hand?
Old 10-03-2005, 11:39 AM   #17
I did with mine...but just see if you can drive somewhere to compress and uncompress that side several times using the weight of the car.
Old 10-03-2005, 06:30 PM   #18
drive ti a bit and let us know if its ok or not, we can then go from there.
Old 10-03-2005, 07:01 PM   #19
rpm
ok so heres the update i went to my friends shop and he looked everything over and said it was installed kool so now just go get an alignment and let it settle... he said the street must b really ****ed... thx for all the immediate help guys appreciate it
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Solid Rear Suspension Setup Thomas91169 1996-2004 Mustang GT 16 12-27-2006 01:51 PM
finally doin the rear suspension... Bane- Pictures and Videos 13 04-01-2006 12:02 PM
Rear Suspension problems BigL34461 Pre-2005 V6 Mustang 3 03-06-2006 01:58 PM
Rear suspension suggestions MustangMatt Pre-2005 V6 Mustang 15 12-20-2004 03:05 PM
03:42 AM
